Top Fuel Pics
strad
117
Re: Top Fuel Pics
It comes from pumping nitromethane in and compressing it to near soild state before igniting it.
Something I have always found intersting is that yes a T/F engine turns from 7 to 8 thousand RPM, but a run only lasts 3.8 seconds...break out your calculators...How many times does that engine actually fire during those 3.8 seconds? Make your math simple,,call it 4 seconds and an average of 8000RPM. And THAT pushes you to over 300mph? :shock: :shock: :shock: :lol:
Sir Stirling Moss
thearmofbarlow
thearmofbarlow
Re: Top Fuel Pics
strad wrote:It comes from pumping nitromethane in and compressing it to near soild state before igniting it.
Just shows you how ungodly terrifying nitromethane is.
When I was about 13 I went to the NHRA nationals in Ennis (just southeast of Dallas) with my dad and some friends. I was walking through the pits when one of the teams fired up their car. Of course, I'm standing right behind the thing and ended up with a face full of nitro exhaust. Horrid. You'd have to be like three inches from a regular car's exhaust to get the same kind of immediate burning eyes and closed up windpipe, and I was about twenty feet away. Nasty stuff.
But ever so fun. :D There's nothing quite like the sound and fury of a nitro powered car booming down a quarter mile. I might have to make the trip out there again this year.
strad
117
Re: Top Fuel Pics
They have revised the estimated horsepower from 8000 to 9500-10,000. :shock:
thearmofbarlow..Yeah it can really take your breath away. I love it.
Sir Stirling Moss
donskar
donskar
Re: Top Fuel Pics
@ thearmofbarlow:
When I was 16 I was gofer for a hometown top fueler -- wiping off the slicks, helping line up the car at the line, etc. One night at a little 1/8 mile strip in Mercer, PA I made the mistake of wearing my pride and joy -- a sheepskin-lined suede leather jacket. The fueler fired as I was pushing on a slick and I got a zoomie-load full in the chest. That beautiful jacket forever more had the consistency of cardboard.
donskar
donskar
Re: Top Fuel Pics
Plain-talk look at top-fueler-type engines from today's New York Times (technology mixed with push rods):
http://www.nytimes.com/2012/08/05/autom ... t.html?hpw
Richard
Richard
Re: Top Fuel Pics
strad wrote:How many times does that engine actually fire during those 3.8 seconds?
Just 506 revs in 3.8 seconds. So each cylinder only fires 253 times - do you replace the plugs for each run?
I'm amazed at how it is possible to force a gallon of fuel per second into the cylinders. I presume that is a gallon of fuel, there would be a much bigger volume of air:fuel mix? What's the volume at atmospheric pressure?
countersteer
countersteer
Re: Top Fuel Pics
richard_leeds wrote:
strad wrote:do you replace the plugs for each run?
Actually, they're consumed on every run! Yes, melted away. They're pushing amps through the plugs on the order of a welder. Once the thing gets on full song it heats to the point that the mixture auto-ignites. That's why the shut it down with the fuel shut-off. Shutting off the ignition will do nothing at that point.
flynfrog
Re: Top Fuel Pics
the plugs burn off at the 60 foot line. You not only replace the plugs but also the valves. Some where I have an awesome video of top fuel fuel injector at full tilt it looks like a fire hose.
Richard
Richard
Re: Top Fuel Pics
I'd expect the valve seating would be critical for maintaining the high compression, does that drop off towards the end of the run?
Also, how are the valves replaced in a 90 min turnaround? I guess the cylinder head is designed for a quick plug and play replacement, and you'd not have time to carefully use grinding paste for the valve and seating?
flynfrog
Re: Top Fuel Pics
richard_leeds wrote:I'd expect the valve seating would be critical for maintaining the high compression, does that drop off towards the end of the run?
http://www.hotrod.com/techarticles/engi ... ewall.html
Looking at this article its not just the valves but a full bottom end rebuild as well I think they reuse the crank.
Scootin159
Scootin159
Re: Top Fuel Pics
richard_leeds wrote:Also, how are the valves replaced in a 90 min turnaround? I guess the cylinder head is designed for a quick plug and play replacement, and you'd not have time to carefully use grinding paste for the valve and seating?
Pre-assembled sub-assemblies + well trained mechanics:
[youtube]http://www.youtube.com/watch?v=qVrvsVZCF7o[/youtube]
strad
117
Re: Top Fuel Pics
For some reason people are always tripped by the last statement in this video.
[youtube]http://www.youtube.com/watch?v=7iCcgND- ... re=related[/youtube]
Sir Stirling Moss
hardingfv32
hardingfv32
Re: Top Fuel Pics
strad wrote:They have revised the estimated horsepower from 8000 to 9500-10,000.
It is a little odd, the HP numbers have been climbing at about 500 HP per season over the last few years while almost nothing has change. The nitro % has been fixed for many years. The engine is very restricted by the rules. You can not introduce a new part without sanction body approval. The sanction body has absolutely no interest in increases of performance.
I think the HP numbers are BS fed to the viewing audience.
Brian
hardingfv32
hardingfv32
Re: Top Fuel Pics
Turnaround times were reduced to speed up the show. 75, 65, and 60 minutes as the rounds progress. As you work through the brackets running few pairs, you start to run out of races to fill the time gaps.
Brian
strad
117
Re: Top Fuel Pics
Brian
Well I wish I had recorded the Northwest Nationals for you. They have been saying 8000HP for ages Brian and so they worked it out mathematically and showed the formula.
Ya know, all you ever wanna do is argue and try to pick stuff apart.
Have you ever been involved in drag racing?
Sir Stirling Moss
