Yes, after you take way the compressor load, you can look at what's left. This varies through the rev range obviously, as the efficiency of turbine and compressor vary.But for simplicity you can use one value for both.WhiteBlue wrote:That calculation applies to the compressor side which I assume needs less power compared to the potential in the exhaust gas. The reason I make this basic assumption is the history of super efficient piston aero engines after WWII and serially turbo charged plus turbo compounded commercial truck engines you find today.ringo wrote:For white blue, this is smikle's calculation a while back in the engine thread. You really need charts or a program to find enthalpies.
First you deal with the compressor work. This comes off the turbine.
After doing all smikle has done, you can look at the quality of the exhuast that's left back to figure out how much load the turbine can take.
This is all limited to the exhaust energy, you can't get more than that, and you can't take it all.
I will try and do a whole calculation, engine and turbine, but it's going to take some time, since i have to refresh my memory.
One thing though, you cannot use every drop of energy, the turbine exhaust pressure has a role to play in what's left.
All that matters is that the generator load + compressor load is not more than the energy coming from the exhuast manifold.
I'm gonna do the calculation, gimme a while.
