IMO Cd of an F1 car is already approaching "brick"JohnsonsEvilTwin wrote:So a brick of an aero design would be better under braking?
I wonder why you did not mention downshifting. Using the engine braking is something we should also take into account.autogyro wrote:I think it also important to realise that the driver is not just brakeing to slow the car without wheel lock.
The driver is also using steering and throttle as well as the brakes to unsettle the car, position it relative to the corner entry with all forces in a chosen balance, so as to achieve the shortest time through the corner and the fastest exit speed.
Well cars are different from each other in terms of 'downforce' and the place of 'center of pressure' they produce at each speed. So the more downforce amount you have, and the further this downforce is towards the front wheels relative to other cars at a given speed, the more you can keep your brake pressure as you slow your car down.Caito wrote:
Up to this point(all caliper, etc being equal) all drivers brake in the same distance, and a better driver would only start to take advantage when the tires reach their limit. The driver who is more capable of being at the limit will brake "better".
How can we know at which (maximum)speed is the driver capable of blocking the wheels? With this we could know how much of an influence does a better or worse driver can make in braking.
As far as I've understood, by removal of engine braking systems EBS systems from start of 2008 onwards, drivers have to be more cautious on braking to not to lock the rears up. Given the fact that, during a generic braking and downshifting period, EBS intelligently tried to use throttle to keep the engine alive enough and compensate and over-downshifts which normally ended up to rear wheel lock ups because of engine braking phenomena. Now, they should be more carefull to not to over-downshift. Thats why they have more tendency to put more loads on front wheels to reduce the punishment of an over-downshifting mistake. So if they don't, it ends up in engine braking added up to actual braking, tires just won't handle it and tear off in blocking.mep wrote: I wonder why you did not mention downshifting. Using the engine braking is something we should also take into account.
Indeed JET, remember that power is force times speed;JohnsonsEvilTwin wrote:So a brick of an aero design would be better under braking?xpensive wrote:At 328 km/h, the air-resistance in itself is worth pretty much the same as your engine power deccelleration-wise,
lifting-off 550 kW gives you a braking force of 6 kN, 18 kNm if you wish to translate it to an equivalent "braking torque."
6000 N of force on a 700 kg object, means a deccelleration of 8.57 m/s^2 ( 0.87 g), this from air-resistance only!
Think about it.
This is not my quote!Tec5nical wrote:As far as I've understood, by removal of engine braking systems EBS systems from start of 2008 onwards, drivers have to be more cautious on braking to not to lock the rears up. Given the fact that, during a generic braking and downshifting period, EBS intelligently tried to use throttle to keep the engine alive enough and compensate and over-downshifts which normally ended up to rear wheel lock ups because of engine braking phenomena. Now, they should be more carefull to not to over-downshift. Thats why they have more tendency to put more loads on front wheels to reduce the punishment of an over-downshifting mistake. So if they don't, it ends up in engine braking added up to actual braking, tires just won't handle it and tear off in blocking.mep wrote:autogyro wrote: I wonder why you did not mention downshifting. Using the engine braking is something we should also take into account.
Yeah, sorry! I will resolve it nowautogyro wrote: This is not my quote!
