Wow...Thanks man, that's a really good article =D> . Seems multi element wings allow you to have, technically, a larger wing with less separation, as well as increasing the pressure differential. Also it seems that after 13 deg AOA the flow starts to become turbulent, but since the slot gaps tend to pull the wake of each previous element, in addition to maintaining a laminar flow across the interrelated surfaces. I guess teams use three elements on the front wing because of space constraints, and because eventually you get into the realm of diminishing returns.
What still puzzles me is why do front wings feature all those flip ups towards near the end plates, and in the middle of the wing elements in the Mclaren? Those small winglets can't possibly create much downforce, do they act like dive planes/turning vanes? Do they act in conjunction with the end plates? Or do they interact with other elements of the front wing? Kind of like how the old diffusers worked with the rear wings. Maybe the up wash they generate helps pull the air under the front wing.
