McLaren MCL35
cyclon
-2
Re: McLaren MCL35
diffuser wrote:
21 Feb 2020, 15:44
cyclon wrote:
21 Feb 2020, 13:43
Rake is a bit high again ...
Hopefully front wing updates will help lowering a bit.
You don't want the rake lowered. If they lower the rake, they're likely failing at sealing the floor. It's easier to seal the floor at a lower rake.
The whole idea of the rake is like having an adjustable rear wing. The rear suspension tension is setup to keep the hight at the speeds that they take the high speed corners in. Then squat in the straights where you don't need the DF. As the car squats the rear wing angle leans back and drag is reduced.
Agreed! But it needs about 5% or so lowering . It's a balance thingy between drag and cornering also will help exiting slow corners. New back suspension setup looks promising to that adjustment! This week it will saw whether the slight lowering can be done if correlation is good enough again!
I loved the iconic McLaren-Honda
But most of all i love McLaren . After all first contact made with M23 that had a Ford Cosworth PU
Re: McLaren MCL35
No it doesn't.
f1rules
f1rules
594
Re: McLaren MCL35
Ok so let me try and understand, mclaren has what, 100 aero engineers, they spec a car and develop it through hours of cfd and windtunnel, only last week they finally got to experience themselves if their real life version works as exspected, only last week they started to test different rake angles to see if the cfd/wndtnl model optimum, is also real life optimum or if they gain anything from increasing or decreasing rake. And still some in here argue they should increase or decrease the angle, im not even sure they are 100% themselves yet...
the EDGE
the EDGE
67
Re: McLaren MCL35
PhillipM wrote:
25 Feb 2020, 16:01
No it doesn't.
I’d pay good money to know where some people get their ideas from, it’s certainly not from reading F1T forums or watch YouTube clips that’s for sure :lol:
ShaquillesWheels
ShaquillesWheels
Re: McLaren MCL35
thestig84 wrote:
24 Feb 2020, 14:59
Can't see much like an indent back there on this pic of Norris's 4
https://www.racefans.net/wp-content/upl ... 054-31.jpg
Upper right of Velo and below Splunk there seems to be signs of overheating on the bodywork?
aral
aral
26
Re: McLaren MCL35
Reflection in the paintwork.
thestig84
thestig84
Re: McLaren MCL35
ShaquillesWheels wrote:
25 Feb 2020, 19:04
thestig84 wrote:
24 Feb 2020, 14:59
You are quite right. It is shown worse in some other images. Little bit hot in that spot..... Im sure they will address it for this test
Lucky
Lucky
157
Re: McLaren MCL35
25 Feb 2020, 19:04
thestig84 wrote:
24 Feb 2020, 14:59
I'm sorry, I can't go into details. But nothing worrisome.
Re: McLaren MCL35
Lucky wrote:
26 Feb 2020, 08:45
25 Feb 2020, 19:04
thestig84 wrote:
24 Feb 2020, 14:59
https://twitter.com/ivanlda/status/1231 ... 64640?s=19
What is this about ??
Lucky
Lucky
157
Re: McLaren MCL35
mclaren111 wrote:
26 Feb 2020, 08:52
Lucky wrote:
26 Feb 2020, 08:45
25 Feb 2020, 19:04
Ivan's comments about overheating.
NiyolHuayra
NiyolHuayra
Re: McLaren MCL35
Can't wait to see new bits of the car over the test days! Hoping for some nice photos.
Re: McLaren MCL35
aral wrote:
25 Feb 2020, 19:47
Agreed. These same areas are present on the black parts of the engine cover, all around the same area.
bauc
Re: McLaren MCL35
the EDGE
the EDGE
67
Re: McLaren MCL35
McLaren running original wing again?
https://www.gptoday.net/en/photos/f/5e5 ... fc26a9.jpg
bauc
Re: McLaren MCL35
the EDGE wrote:
26 Feb 2020, 10:23
Well they are doing aero mapping so I guess they will do back to back again with ''old'' and new FW spec
