Yes of course
In other forum ;
Quote:
Originally Posted by Brutus1967 View Post
The efficiency of a vacuum engine is horribly low: the first ocean liners had what was then called "atmospheric steam engines" in which the actual labour was done by the atmospheric pressure acting on one side of the working piston, and the vacuum created by condensing the steam on the other side of the working piston.
The efficiency was less than 5%, and the first vessels crossing the atlantic ocean on engine power alone, were known to need to burn wooden chairs and other furnitures, window sills and deckplanking, in order to reach the other side of the pond because the coal fuel was finished...
Brgds, Bert
Well, not good with this efficiency .. You mix two completely different concepts, the efficiency of the steam engine The carbon burning, with the efficiency of a wind turbine ( in the negative pressure wing profle NACA - FELIKS ).
When energy comes from burning, really important thing is the efficiency with which it is done. Because we have a limited amount of fuel has just available. and then the 5% is actually a small value .. and the ship has trouble swimming.
But the sail-powered ship, even as it has efficiency of 2%, it still can freely sail around the globe całakule around, for this, the wind energy at sea is missing and NEVER run out why performance in this case the energy of secondary importance, if we have an infinite the amount of free energy to use .. Only at the very beginning, that the construction, we need to build a bigger engine .. Well, for example, in this case, if we want to have 100% efficiency Such as is the atmospheric engine would have to be 20 times greater. So that you can imagine .. .Then all energy supplied will be free to move the engine, and it is certainly several times higher efficiency of such an engine than the normal propeller fan of the same size ..
This engine is sufficient to tens of millibars vacuum, that he began to work very efficiently .. Such differences of pressure observed in Nature, during hurricanes, or tornadoes ..No and efficiency of what is a tornado ?? Large, certainly a big ...
Write or understand the performance issues that the traditional concept is here entirely at long plan, since it does infinite quantity of wind energy to use and we will be sure to have it for the next thousand years. . At most, we can improve the efficiency of its use, using modern methods of testing and optimization of these completely new systems caused by wind Red Baron Windmill..
Andrew
