Yes, "A" must droop too, but whole sequence of drooping is initiated by "C" I think.strad wrote:"A" is what droops ..well the whole thing droops really... and "A" seals the wing to the track . On Speed they showed it and also how the bottom outside of "A" gets shredded by contact with the track...I assume we will soon have titanium rub blocks making nice sparks...be great at the night races...
I'm not so sure strad, looks the same from two angles, could it be a cleverly applied support-rib of sorts,strad wrote:Optical illution ..it is I believe,,the leading edge of "B"
A talent you share with other prominent members of this here forum.strad wrote:I think I'm right
You can't be sure of that. It's not that simple I'm afraid, but good point. We don't know the exact size (long/width) of each section of the RB wing, and we can't see the famous "adapter" which the team must provide for measurement. So for now nobody can tell where the (FIA) load is applied exactly on this wing. I wish someone can. Pictures anybody ?xpensive wrote:
Me on the other hand, I think I've found it, look at that crooked reinforcement-rib, probably going thru the entire wing as a rope, and imagine what happens when you load the wing in front of it (FIA-test) vs behind it (reality)?
Eureka.
Ahh!, Ive read too many comments like this now. You can read NOTHING into the bending stiffness of the wing at this point without knowing what the change in wall thickness is. I can almost guarantee that the layup increases here so there isn't such obvious bending, otherwise they would not be passing the vertical load tests.marcush. wrote:
on this pic you can clearly see wing section B is reducing in thickness considerably
towards the hinge point allowing it to bend /almost buckle upwards as soon as
speed is pushing section c downwards.this will allow the whole outer section first to
rotate down an to bow down .
This is not true, this is what I'm trying to say.marcush. wrote: ...And of course a profile with a lot of section height will not bend as easily as a slim one ,no matter how much material you put there its not all material shape is just as important.
