If there are multiple pick up pumps I would expect that they pick up from different places. If those pumps are not used to empty the tank there will necessarily be some additional plumbing.saviour stivala wrote: ↑08 Dec 2019, 17:21There is no multi-pick-up systems but multi-pick -up pumps (3 or 4 are used) in the system and the current fuel system used (pressured collector pot) is not what I imagine it to be but as described by an ex-Williams engineer.
You imagine the system in use is the same as described in an article describing that used by V8s in the same way I imagine the system in use now on the V6 turbos is the same as will be used in 2021. Neither of us know. And for this discussion it makes little difference.
