Mercedes GP W02
Pierce89
Re: Mercedes GP W02
hardingfv32 wrote:This seem like a little chicken or egg question?
The same models used to generate some of the simulator codes are used to optimizes the chassis for a race on a post shaker,etc. Shouldn't the computer be the one setting up the car?
Is this all about seeing if the driver can deal with the computer dictated setup? Dumbing down the setup to reinforce the driver's all important confidence.
I wonder if a driver spends enough time in the simulator, can his confidence grow to accept a setup that initially did not inspire confidence? Instead of simulator it could be called a driver psychology manipulator.
Brian
Yes the computer does come up with a theoretical best setup. It's usually virtually undriveable, so they use the simulator to work back from there to a good baseline for the track.
ForMuLaOne
ForMuLaOne
Re: Mercedes GP W02
With the new exhaust solution there might be a reason for keeping the double radiators...because now they can evacuate air right behind them. It won`t cost efficiency compared to others, who also need to use this position. Or is there a limited size for the holes in the bodywork, where exhausts are pointing rearwards?
JohnsonsEvilTwin
Re: Mercedes GP W02
The whole reason on getting double rads was so the car could have a short wheel base. It cost them 4 months development getting the cooling right.
Next year Brawn has said the car will certainly be longer than the current W02. So the only reason to keep the unnecessarily complex arrangement would be to get a super compact rear "coke bottle" shape.
Red Bull achieve this without double rads.
Also, having this arrangement increases centra of gravity, an Achilles heal of the current package.
More could have been done.
David Purley
yener
Re: Mercedes GP W02
raymondu999 wrote:Mind pointing out the fine tunings?
Sorry couldnt upload before..
Here is a picture of the new (under) and old (up) fw
"Life is about passions - Thank you for sharing mine" MSC
elf341
elf341
Re: Mercedes GP W02
Good spots.
There looks also to be a new gurney just above the "syntium" logo on the upper element
hardingfv32
hardingfv32
Re: Mercedes GP W02
Forgive me if this has been covered before, but what is the purpose of what looks like the top of a small concave diffuser (circled in red) either side of the mounting struts?
Brian
adrianjordan
Re: Mercedes GP W02
hardingfv32 wrote:Forgive me if this has been covered before, but what is the purpose of what looks like the top of a small concave diffuser (circled in red) either side of the mounting struts?
Brian
Unless I'm missing what you're referring to, aren't those the camera mounts..??
Favourite team: McLaren
hardingfv32
hardingfv32
Re: Mercedes GP W02
No, these would be the first objects on the top surface of the main element outside the mounting struts.
Brian
MIKEY_!
Re: Mercedes GP W02
Do you mean this bit? I have been wondering this myself.
Byronrhys
Re: Mercedes GP W02
raymondu999
Re: Mercedes GP W02
When did they debut a double airbox design? I don't remember that
失败者找理由,成功者找方法
MIKEY_!
Re: Mercedes GP W02
Monaco
elf341
elf341
Re: Mercedes GP W02
don't know if it's just me, but I love that photo of Geoff Willis with a look of concern on his face whilst looking at the rear of Nico's car.
Almost like a "wtf is going on here?!" -- he's probably looking at some of MGP's oft-featured heat-dispersion grills. I imagine for an aerodynamicist that would be akin to someone using salotape to fix a broken pair of Oakleys - it ain't cool anymore :lol:
DRCorsa
DRCorsa
Re: Mercedes GP W02
elf341 wrote:don't know if it's just me, but I love that photo of Geoff Willis with a look of concern on his face whilst looking at the rear of Nico's car.
The rear cover is removed in that picture.. :P
Pierce89
Re: Mercedes GP W02
Byronrhys wrote:Image
Geoff doesn't like what he sees
