McLaren MCL38
Emag
Emag
109
Re: McLaren MCL38
Sidepod almost completely reshaped. Waterslides gone for the most part for a cleaner airflow at the top, while having a much bigger undercut. Reminds me of RB9 a bit, but with 10 years worth of advancements, bodywork is much tighter. They have also tightened the engine cover and have their own implementation of the Mercedes' "sausages". Not really to the same extent/effect that RBR and Merc have/had it, but similar idea.
Front-wing definitely looks different, but more comparison pics would help to see the difference. Same with the mentioned suspension changes.
Rear-end really seems like it's being treated differently though, especially the part in front of the rear brake ducts.
Developer of F1InsightsHub
mwillems
45
Re: McLaren MCL38
Can't really tell properly but the front wing seems to still be shaped like the spoon of the main plane.
-Bandit
_cerber1
266
Re: McLaren MCL38
The complete set is only for Lando, Oscar will only receive parts of the upgrades here, the rest in Imola.
f1rules
f1rules
621
Re: McLaren MCL38
very rb inspired, bigger upper lip, small waterslide starting late, fw is difficult to judge, but seem very similar
LionsHeart
LionsHeart
Re: McLaren MCL38
mwillems wrote:
03 May 2024, 17:20
I think this is the previous specification. I don't see any changes.
mwillems
45
Re: McLaren MCL38
LionsHeart wrote:
03 May 2024, 17:24
mwillems wrote:
03 May 2024, 17:20
It looks different to me, but more on the elements.
I think the light is making it tricky to see however.
-Bandit
LionsHeart
LionsHeart
Re: McLaren MCL38
mwillems wrote:
03 May 2024, 17:26
LionsHeart wrote:
03 May 2024, 17:24
mwillems wrote:
03 May 2024, 17:20
I think the light is making it trick to see however.
Yes, maybe. A different perspective is required to understand the overall geometry.
mwillems
45
Re: McLaren MCL38
I'm not convinced the watersides have changed I think it's just the shadows are hidden and it looks smooth.
Need some pics from practise.
-Bandit
LionsHeart
LionsHeart
Re: McLaren MCL38
Emag wrote:
03 May 2024, 17:22
Right. The undercut under the sidepods has become deeper and extends further along the rear. A very aggressive part of the updates.
Regarding the front suspension. I was able to see a flattening at the upper front control arm. I didn't see any other visible changes.
Luscion
Luscion
113
Re: McLaren MCL38
Emag
Emag
109
Re: McLaren MCL38
mwillems wrote:
03 May 2024, 17:29
Nope, waterslides are definitely changed.
Before -> https://pbs.twimg.com/media/GLb3DH3XsAA ... name=large
After -> https://i.ibb.co/Z6qwPDS/15-F08757-D376 ... C3-BC6.jpg
Just follow the crease towards the engine cover and see how much steeper it is in the older spec almost immediately after the inlet. That's not the case anymore, the "fall down" only happens at the rear-end.
saputra_25
saputra_25
Re: McLaren MCL38
Luscion wrote:
03 May 2024, 17:08
Reshaped sidepod inlet and top wing element. (both images from the upgraded car)
https://pbs.twimg.com/media/GMqbkBrW0AA ... name=large
https://pbs.twimg.com/media/GMqbkBpXwAA ... name=large
The upper wing close to sidepod inlet is way bigger than previously
f1rules
f1rules
621
Re: McLaren MCL38
its completely different
mwillems wrote:
03 May 2024, 17:29
f1rules
f1rules
621
Re: McLaren MCL38
exactly
Emag wrote:
03 May 2024, 17:33
mwillems wrote:
03 May 2024, 17:29
LionsHeart
LionsHeart
Re: McLaren MCL38
Against the backdrop of all this, a single-element beam wing looks interesting. Here we can really say that it is unloaded and designed to reduce drag.
