2023 Scuderia Ferrari F1 Team
CouncilorIrissa
CouncilorIrissa
Re: 2023 Scuderia Ferrari F1 Team
This Sainz onboard on the exit of Juncao looked atrocious. Poor drivers.
Xyz22 wrote:
05 Nov 2023, 19:52
The depressing thing is that next year will be the same
If it was an engine issues i’m going to be quite angry
Depends on how Vasseur responds, he finally noted issues with strategy after Austin fiasco. Hopefully he'll also realise they have issues with mechanics (remember also the Spain), in the sense of how they work and what the check-up procedures are. Will only be able to judge his direction next year and long-term strategy in late 2025 and 2026...
Xyz22
Xyz22
123
Vanja #66 wrote:
05 Nov 2023, 20:41
Xyz22 wrote:
05 Nov 2023, 19:52
I have no faith whatsoever.
This was the perfect race to start from the pitlane. They had all the info available to understand this was going to be the best decision, but they didn't.
They are just incompetent. All the team should be changed. There is nothing to save.
https://www.motorsport.com/f1/news/lecl ... /10543287/
"I don’t think it’s a hydraulic problem. I mean, I know what it is. I cannot go too much into detail.
“Then there was an engine thing that made me lock the rear wheels and then obviously I spun and hit the wall. I couldn’t do anything.”
PierreW
PierreW
Leclerc's run of bad luck is astonishing. One can only hope it will turn dramatically next year.
Now Fabrega says electrical problems
It's possible that the ECU that they used since the beginning of the season reached end of life?
And from Duchessa/formu1a.uno:
https://formu1a.uno/verstappen-poi-norr ... c-fa-male/
his SF-23 suffering a problem relating to the control and safety systems on the engine .
Xyz22
Xyz22
123
PierreW wrote:
05 Nov 2023, 22:02
This is not bad luck. It's just an incompetent team.
PierreW
PierreW
Xyz22 wrote:
05 Nov 2023, 22:10
PierreW wrote:
05 Nov 2023, 22:02
It doesn't explain why it affects Leclerc so much more than Sainz.
Xyz22
Xyz22
123
PierreW wrote:
05 Nov 2023, 22:30
Xyz22 wrote:
05 Nov 2023, 22:10
PierreW wrote:
05 Nov 2023, 22:02
His side of the garage is more incompetent.
catent
The number of mechanical mishaps over the past several seasons, specifically on Leclerc's side of the garage, is entirely unacceptable. It's inconsistent with the number of mishaps seen with other teams, and it's inconsistent with the number of mishaps seen on Sainz's side of the garage. At best, this means Sainz's side of the garage is far more competent; at worst, it could be the result of the political leverage held by Spanish powers-that-be within Ferrari.
Leclerc's garage needs to be entirely cleaned out. It's absurd, ridiculous, and totally unacceptable for a Formula 1 team.
I'd be curious why RC didn't allow Leclerc to grid following the red flag. Assuming the suspension was undamaged, they could've put on a fresh front-wing and given it a second shot. Shame.
catent wrote:
06 Nov 2023, 03:31
Probably because when you get out of the car and walk away you are considered retired.
dialtone
dialtone
118
catent wrote:
06 Nov 2023, 03:31
RBR fans and their short memories. It’s like living an eternal bliss. Did you forget Perez coming back from the pits, basically after he probably had already showered, to pay the penalty in suzuka?
He didn’t restart because his car was broken, engine had emergency shutoff. Had he made it back on his own he was going to take part, but he didn’t even start the race.
dialtone wrote:
06 Nov 2023, 05:24
Actually, you need to stay in the car at all times while on track. In your garage you can leave the car and also return to it and get back on track. That's why Russell had a DNF at Silverstone last year, he left the car to check up on Zhou...
There was nothing for Leclerc to do yesterday.
Xyz22
Xyz22
123
The on track operational team is easily the worst of the grid, no doubt.
Terrible quality control
Small improvements in performance from Friday to Saturday compared to other teams
Terrible strategies
search
looks like it was a happy day for some, at least ;)
