Afterburner
Owen.C93
Owen.C93
191
Here's the full video. Screenshots come from 2:20 onwards.
https://www.youtube.com/watch?v=PCWXd29lJtQ
lio007
327
This engine looks very similar or exactly the same as in the presskit from June?
http://www.renaultsport.com/IMG/pdf/rsf ... final2.pdf
dren
228
Yeah, looks the same as the press kit.
Honda!
SectorOne
Afterburner wrote:Image
With that airbox inlet i assume it´s for the dyno? Or will they come out running these next year??
And what are the two other carbon boxes?
CMSMJ1
CMSMJ1
The vertical box on the front is the oil tank is it not?
IMPERATOR REX ANGLORUM
Holm86
261
Oil tank at the front yes.
And that airbox is meant to connect with an intercooler which will probably be situated in the sidepod. That's why is has that angle.
See this photo SectorOne :
SectorOne
Ahh thanks, forgot that earlier pictures had a proper airbox.
Now i can see how things are connected more clearly, thanks again.
oil, intercooler, airbox from front to back.
diemaster
diemaster
timbo
timbo
113
Wow! The turbo is gigantic!
monsi
monsi
That draped Ferrari engine so looks like a miniature elephant to me, with swept ears and a little tusk prodding out the front. I always did think a bit sideways ... :wink:
FW17
185
2014 FIA Sporting Regulations outline
“For the purposes of this Article 28.4 the power unit will be deemed to comprise six separate elements, the engine (ICE), the motor generator unit – kinetic (MGU – K), the motor generator unit – heat (MGU – H), the energy store (ES), turbocharger (TC) and control electronics (CE). Each driver will therefore be permitted to use five of each of the above six components during a Championship season and any combination of them may be fitted to a car at any one time.
“Should a driver use more than five of any one of the elements a grid place penalty will be imposed upon him at the first Event during which each additional element is used.”
Cold Fussion
Cold Fussion
95
That's a changed from before isn't it? Before wasn't any change on another of the components of the power unit deemed a change in the power unit, and you only had 5 of those changes?
240
monsi wrote:That draped Ferrari engine so looks like a miniature elephant to me, with swept ears and a little tusk prodding out the front. I always did think a bit sideways ... :wink:
Where are you seeing the Ferrari engine?
monsi
monsi
Pic in diemaster's post seems to have disappeared along with the original tweet !
Can still be found with google image search
