63l8qrrfy6
63l8qrrfy6
368
saviour stivala wrote:
14 Jan 2020, 09:54
If your educated guess based on the fact that the use of steel liners separate from the block casting is the best solution in terms of bore distortion and friction reduction, it must have been the same best solution when F1 engine manufacturers abandoned the use of steel liners even with engines revving past the 20k RPM mark.
No, not at all.
N/A engines were just a little over 100 bar peak cylinder pressure and had to do fewer races. They were also running relatively rich and considerably cooler.
Current engines are probably 3 times the cylinder pressure, hotter and have to do more races. The stud pretension (which is the what drives high order bore distortion) is also increased in line with peak combustion loads.
I will re-iterate that from experience with engins of lower specific output and similar life that nothing you can put on the aluminium will stay there. Yes there are DLC coatings with lower process temperature that can be applied but they will have lower adhesion and lower hardness.
saviour stivala
saviour stivala
Just_a_fan wrote:
14 Jan 2020, 11:39
14 Jan 2020, 09:54
Are the engine materials regulations and limits on what can be used the same now as then? Were they using something then that is no longer allowed?
As to the use of material I don’t recon there being any differences between then and now. Could be some related to coating thicknesses.
saviour stivala
saviour stivala
Mudflap wrote:
14 Jan 2020, 12:45
14 Jan 2020, 09:54
No, not at all.
So who of the four manufacturers has reverted back to using steel cylinder liners, or have all four did so because of the higher combustion pressures?
648
Just_a_fan wrote:
14 Jan 2020, 11:39
14 Jan 2020, 09:54
abandoning discrete liners ? ....
would help bore increase/valve increase/stroke shortening/rpm increase without the disruption of increasing cylinder centres
life was unimportant
then came the engine freeze
now we require long engine life - and so the rules dictate dimensions that force a conservative design configuration
Zynerji
111
Are any of the manufacturers following BMW's lead from the V8 era and making the head and the cylinders a single piece?
With what SavSat has said, the head gaskets/studs seem to be the weak spot.
14 Jan 2020, 12:56
Mudflap wrote:
14 Jan 2020, 12:45
14 Jan 2020, 09:54
No, not at all.
Is there anything else than using steel liners in this formula?!
For me Steel is no brainer ever since the regulations came out.
Are there people out there that believe anything else would be used in an 850hp 1.6 liter engine?! I need some of that purple kush.
63l8qrrfy6
63l8qrrfy6
368
Zynerji wrote:
14 Jan 2020, 16:37
Yes, mechanically BMW's approach is much more robust however it drastically limits the valve size (length and dia) and valve angles that can be assembled.
If you look at published data for V8 engines of that period BMW's 750 hp output was quite modest compared to Toyota's 760 and Cosworth's 756 in 2006. Both Honda and Cosworth reached 772 hp with further development.
At the time it was speculated that the deficit was due to compromised port shape as they could not fit long enough valves.
From what I've seen so far I believe all 4 manufacturers appear to use conventional head/block joints.
63l8qrrfy6
63l8qrrfy6
368
Funnily, while trying to find the Cossy V8 power posted earlier I found an article with Mahle's Fred Turk discussing potential liner tech for F1 V6 (back in 2013) and he seemed to think aluminium bores could work too. Went as far as suggesting that they were experimenting with using Nikasil as an adhesion layer for a better coating.
Mudflap wrote:
15 Jan 2020, 00:56
FRM for the win! Let's you use aluminum sleeves with better heat dissipation, very resistant to cracking.
subcritical71
90
I was looking up nikasil on the mahle website when I came across this describing the SF90...
MAHLE Motorsport in Formula 1.
The top tier of motorsport and MAHLE Motorsport are made for each other. Both have maximum performance in their genes, both represent the peak of what is technically feasible. For over 45 years, we have been pushing technological boundaries with Scuderia Ferrari. These days, as technology partner, we supply the iconic team with components such as pistons, as well as innovative technologies such as the lean-burn combustion system MAHLE Jet Ignition®.
63l8qrrfy6
63l8qrrfy6
368
godlameroso wrote:
15 Jan 2020, 03:36
Mudflap wrote:
15 Jan 2020, 00:56
If FRM was any good Honda would have used it in F1. Instead they too went with good old Nikasil.
Mudflap wrote:
15 Jan 2020, 23:00
godlameroso wrote:
15 Jan 2020, 03:36
Mudflap wrote:
15 Jan 2020, 00:56
Maybe it's a weight thing, as FRM used by Honda used a separate sleeve cast into the cylinder around .7mm thick. Whereas good ol' Nikasil can be spray deposited on machined bore. No "sacrificial" sleeve and 1/3rd of the thickness.
I guess it's a tradeoff because you'll need to redesign the water jackets since Nikasil isn't as good as FRM is at transferring heat. If the car is carrying a few CC more coolant will that weight disadvantage be a better compromise than a heavier block with better heat dissipation.
63l8qrrfy6
63l8qrrfy6
368
There's no thermal disadvantage with Nikasil, not sure where that is coming from.
At 0.1 mm typical thickness there is virtually no increase in thermal resistance.
Plasma spray coatings on aluminum work well to reduce friction and hold oil. But can they really prevent distortion at those extreme cylinder pressures? (more than 500hp per liter in F1)
Is just a gut feeling that F1 is using steel with a coating (chrome ceramic coated?) because is not that much more weight but whole lot security. I could be wrong though.. The other closest engine would be the Porsche 919? Trying to think of turbocharged high hp/liter engine for endurance...
568
Distortion will be a function of the underlying structure. The coating has little effect.
Weight for weight aluminium will distort less than steel.
