McLaren MCL60
Lucky
Lucky
157
Re: McLaren MCL60
Re: McLaren MCL60
At last.
The sidepod inlets are tall and wide. Letterbox style following amr/RB doing the same
Looks like the approach is very similar to RB. Can see the slab part of the sidepod is concave, and the lower section curves aggressively inwards creating an undercutting channel beneath the slabby sidepods. Just like RB. Makes sense to follow this approach now
Remains to be seen what's going on with the downwash portion. Could easily be waterslides, making this an AMR-like car
continuum16
51
Re: McLaren MCL60
Looks to me like they’ve abandoned the partially-swept sidepod inlets they’ve run since about Singapore ‘22. Inlet looks nearly identical to AMR now. Interesting to see they’ve removed the crease in the sidepods; smooth ramp-shape looks very post-Spain Ferrari-esque.
Edit: also the mirror mounting no longer appears to have two vanes but just one for now.
- Mark Twain
MrGapes
34
Re: McLaren MCL60
Lucky wrote:
29 Jun 2023, 16:46
Much more defined undercut between rear outlet and floor, the upper engine cover surface swoops down quite early.
Edit: The rear outlet looks way lower....if you look at it relative to the rear suspension.. maybe no gulley's, but upper surface feeds directly to the beam wing.
Re: McLaren MCL60
More of an amr sidepod then.. those waterslides are deep. Engine cover with the low downwashing shoulder is very amr too. they have integrated a cooling slot underneath the sharkfin just as other teams have done.
Lucky
Lucky
157
Re: McLaren MCL60
scuderiabrandon
111
Re: McLaren MCL60
They have move to the old RB style rounded corner diffuser after Red Bull have moved away from it. There old diffuser is closer to what RB are running now. Feels like they are just following cookie trails all the time.
MrGapes
34
Re: McLaren MCL60
29 Jun 2023, 18:13
Floor protrusion seems far more distinct vertically and horizontally
Rear floor corner no longer has floor cutout with spoon
KimiRai
KimiRai
298
Re: McLaren MCL60
29 Jun 2023, 18:13
Looks similar to the first iteration of the Aston waterslide (pre-Canada).
Re: McLaren MCL60
Haupt image with closer view of floor
kfrantzios
kfrantzios
46
Re: McLaren MCL60
Re: McLaren MCL60
KimiRai wrote:
29 Jun 2023, 18:50
29 Jun 2023, 18:13
Yes it has the appearance of the launch spec RB and the launch spec AMR cobbled together. Considering the timing, this makes sense as this work would have had to have been in the windtunnel since the start of the season. They've even made the sidepod inlet detail more obvious.
If the performance of AMR and RB is anything to go by, then this is a good direction.
A lion must kill its prey.
MrGapes
34
Re: McLaren MCL60
Is that two fence elements close together?
- probably just the angle
Re: McLaren MCL60
Most likely just angle. They're in all likelihood spaced roughly as far apart as they have been previously. Am searching for alternative angle of the region
Goblin42
57
Re: McLaren MCL60
