2023 Austrian Grand Prix - Spielberg, June 30 - July 02
Re: 2023 Austrian Grand Prix - Spielberg, June 30 - July 02
dialtone wrote:
02 Jul 2023, 20:54
vorticism wrote:
02 Jul 2023, 20:50
2 m strip of grass then asphalt does seem like an ideal solution as AR3-GP keeps bringing up. You get the immediate punishment and then get to catch it and slow down on the asphalt run off (more so than gravel, at least). What's the catch though? MotoGP couldn't use it?
I don't think moto would have a problem with that idea
I find it funny that people here believe that nobody ever thought of that already :).
In all likelihood they have a set of known corner edges that could be implemented and discussed them all and couldn't find a compromise that worked and not enough pressure to do it.
Maybe this changes now.
I find it amusing that you treat others' ideas with derision but things you've supported in this thread is exactly the FIA has done this weekend. And it's resulted in this --- in both qualifying and now the race. So forgive me for not taking you seriously in this matter :D
I'm sure they've evaluated these options before.. it's just that they were wrong to dismiss them. The RBR is primarily an F1 circuit and if the race results take hours post-race to decide at this circuit and qualifying has drivers kicked out early for supposed infringements that are later reversed.. it doesn't work as an F1 circuit!
dialtone
dialtone
123
dialtone wrote:
02 Jul 2023, 20:54
What's to take seriously? Send an email to RBR then, they will thank you and this forum for the solution nobody could think of. Evidently they can design spaceships which don't need a track to go fast as they fly through it (so they aren't that good at designing tracks).
Edit: my starting point is simply that people that work on these tracks, and RBR in particular aren't a bunch of morons to begin with.
Stu
DGP123 wrote:
02 Jul 2023, 15:27
InsaneX_Badger wrote:
02 Jul 2023, 15:26
Amateur hour from Lewis
Car won’t turn was his report. Brake issues during first stint
“Car won’t turn”
That sounds quite dangerous….
vorticism
323
dans79 wrote:
02 Jul 2023, 20:56
an example of what a badly place hard preventative measure can do.
https://www.youtube.com /watch?v=kbPRSMJJDZ8
You're comparing grass to a sausage kerb launching a car vertical. Ridiculous. What are you doing.
𓄀
dans79
267
vorticism wrote:
02 Jul 2023, 21:03
dans79 wrote:
02 Jul 2023, 20:56
try re-reading my post, i explained why even grass can be a problem!
201 105 104 9 9 7
dans79
267
Stu wrote:
02 Jul 2023, 21:02
“Car won’t turn”
he is referring to lateral rotation...........
201 105 104 9 9 7
chrisc90
I thought they might have been able to do a 1m wide sunken gravel trap that can be easily lifted out (say 3” deep) and can just hoover all the gravel out. Then there’s a drop in section to cover the hole up for the Moto gp stuff.
Not really sure what else could be out there. Grass has potential for a F1 car to lose the rear end and head sideways or backwards down towards the next turn.
dialtone
dialtone
123
Just to be clear what the argument in this thread seems to be from my perspective:
* They should have had natural track edges, in absence of those each driver can do whatever they want because policing staying on track is bad.
This seems to be the argument I hear. On my side the argument is:
* What happened is also disappointing in my view, but the alternative of allowing drivers differing amounts of leaving track unpunished is not fair at all and IMHO arguably worse than the alternative.
either way FIA needs to continue progress on what technology they want to implement to prevent leaving track unpunished while keeping all track users lives safe.
vorticism
323
dans79 wrote:
02 Jul 2023, 21:04
Loss of traction leading to spin and sub optimal tire barrier strike. The can be assessed, in fact surely already has at most circuits. Don't put grass on those corners if such a problem exists. On the other corners, put grass. Grass won't launch a car though, obv. Is there a specific corner that is a good example where grass would be dangerous? I'm genuinely curious.
𓄀
Zynerji
111
How about teflon or oleophobic, bolt down kerbs 1m from the white line? Just reduce the friction coefficient of the surface to reduce desire to run over it.
Big Tea
99
mwillems wrote:
02 Jul 2023, 20:41
Bring back the gravel so they really regret biting off too much. I'd much rather see instant on track ramifications.
The way thing seem to be going they would call a safety to clean up gravel every time someone put a tyre off.
Zynerji
111
vorticism wrote:
02 Jul 2023, 21:10
dans79 wrote:
02 Jul 2023, 21:04
That grass Timo Glock launched over a few years ago is prob not a great one..lol
mwillems
45
Big Tea wrote:
02 Jul 2023, 21:12
mwillems wrote:
02 Jul 2023, 20:41
Ahahahaha
This is true. And to be fair I can understand why it is difficult to find the right on track solution.
But at the very least the FIA should have tech like Hawkeye to monitor corners. It's not exactly new technology.
-Bandit
dans79 wrote:
02 Jul 2023, 21:04
vorticism wrote:
02 Jul 2023, 21:03
dans79 wrote:
02 Jul 2023, 20:56
Why is Suzuka lined with grass?
A lion must kill its prey.
dans79
267
02 Jul 2023, 21:18
dans79 wrote:
02 Jul 2023, 21:04
vorticism wrote:
02 Jul 2023, 21:03
doesn't make it ok. got on the grass on the entry then dug into the sand/gravel and flipped after
201 105 104 9 9 7
