Ferrari F2012
beelsebob
beelsebob
85
Re: Ferrari F2012
alogoc wrote:https://p.twimg.com/Au0Oks2CEAAJ1g9.jpg
the more i look at this picture the more i wonder!
why the hell dont they use black screws?!!!
They do, they're just less matte than the area around them.
Re: Ferrari F2012
so why do teams reiterate that track testing is useless and not giving any benefit?
Smokescreen anyone?
Sure I have the opinion that you cannot simulate or windtunneltest to the fine resolution needed and get perfect correlation without having acces to fudge factors -and you need those created from real world full scale testing ..but no means of measuring apart from load cell outputs, stopwatch and driver comment ..a bit too much of indirect proof of the pudding in my book.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Indeed the F2012 has the curved strake on the floor & the silver one too like at Mugello.
alogoc
alogoc
-10
Re: Ferrari F2012
why is one silver other not?
heat resistance difference?
http://motorsport.nextgen-auto.com/gall ... un/286.jpg
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
alogoc wrote:why is one silver other not?
It's exactly like what Ferrari used in Mugello. They were obviously simulating this exhaust solution on the 1st day in Mugello. But yes the silver tunring vane should see more exhaust gasses than the curved black strake
Mugello
beelsebob
beelsebob
85
Re: Ferrari F2012
marcush. wrote:so why do teams reiterate that track testing is useless and not giving any benefit?
Smokescreen anyone?
They don't – the teams who happened to have the fastest car at the time did – because they didn't want the others to be able to gain from testing.
Scalex
Scalex
Re: Ferrari F2012
This pic from Autosprint.com shows what appears to be a small hot air exit just above the exhaust exit (between this and the body panel); this would be in line with what I mentioned in my previous post as the differential between this jet of air and the one flowing on top would help directing the gasses as well...
Hot air exit can also be clearly seen at the inner side.
Kiril Varbanov
147
Re: Ferrari F2012
Some informed people told me that the new exhaust solution was tested in both wind tunnels - in Maranello and Cologne (ex-Toyota).
.poz
.poz
50
Re: Ferrari F2012
Scalex wrote:This pic from Autosprint.com shows what appears to be a small hot air exit just above the exhaust exit (between this and the body panel);
so we have 3 different air stream:
fast air above bodywork
slow air from car coolig
fast exhaust
Can this help to direct/seal exhaust by creating a couple of counter rotating vortex ?
Postmoe
Re: Ferrari F2012
My engineering-scouter just exploted with that. Clearly over 9000.
Now seriously, I think it could be true, but that they are also conditioned by their original cooling itinerary. So perhaps they are just forced to do that. Or perhaps a little bit of the two possibilities...
King Six
King Six
Re: Ferrari F2012
These exhausts aren't there for aerodynamics right? Looks to me this is all about managing tyre temperature rather than using the exhaust flow for aerodynamics.
amouzouris
105
Re: Ferrari F2012
King Six wrote:These exhausts aren't there for aerodynamics right? Looks to me this is all about managing tyre temperature rather than using the exhaust flow for aerodynamics.
well...i gotta say u r mistaken my friend..
alogoc
alogoc
-10
Re: Ferrari F2012
Kiril Varbanov wrote:Some informed people told me that the new exhaust solution was tested in both wind tunnels - in Maranello and Cologne (ex-Toyota).
but how?
i tought wind tunnel models dont have working engines?
THE F2012!
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
but how?
They don't, not in the Maranello or old Toyota tunnel. Teams attempt to simulate the exhaust in the wind tunnel, but it doesn't compare to what actually happens on the track.
The point is wind tunnel simulation will be helpful but only to a point. CFD would probably yield better more accurate results, but the tunnel would help. The main thing is that Ferrari has already simulated this exhaust on track. So they obviously feel comfortable with implementing it.
Mazdaboy
Re: Ferrari F2012
Here is a good comparsion from the two different exhaust system:
Every race ends when the chequered flag is out!
