Williams FW36 Mercedes
Re: Williams FW36 Mercedes
It's been mentioned before, but I can't remember if it was in this thread or in the suspension part, it's basically allowing the hub to be excited with little damping at full droop to help retain heat in the inside tyre.
Henning
Henning
PhillipM wrote:It's been mentioned before, but I can't remember if it was in this thread or in the suspension part, it's basically allowing the hub to be excited with little damping at full droop to help retain heat in the inside tyre.
It has been discussed. The discussion starts on page 25 (http://www.f1technical.net/forum/viewto ... &start=360]) of the thead with this post : http://www.f1technical.net/forum/viewto ... 63#p497063
loyfah
loyfah
This video was posted on reddit.com/r/formula1, dont know if its any help.
http://s3.photobucket.com/user/Somersra ... 5.mp4.html
Francesc
Francesc
50
Earnard Beccelstone
Earnard Beccelstone
The second pic really gives an indication as to how much Mercedes have minimised the height of the sidepods.
beelsebob
beelsebob
85
No, it gives a great indication of what cars look like at different angles.
jz11
jz11
19
he may have a point, it's quite fuzzy, but if you would draw a line from top of the rear tyre to top of the front tyre on Mercedes and then on Williams, Mercedes sidepod seems to be just a bit lower, you can even see the front tyre over the sidepod, and from what I can gather from Williams cars geometry, you wouldn't be able to see that front tyre if the car was as far away as Mercedes
p.s. it may as well be caused by speed, downforce or braking etc
Monaco 2014 - Tuesday (20.05.2014)
Monaco 2014 - Wednesday (21.05.2014)
jz11 wrote:he may have a point, it's quite fuzzy, but if you would draw a line from top of the rear tyre to top of the front tyre on Mercedes and then on Williams, Mercedes sidepod seems to be just a bit lower, you can even see the front tyre over the sidepod, and from what I can gather from Williams cars geometry, you wouldn't be able to see that front tyre if the car was as far away as Mercedes
Williams went for a double floor arrangement which makes the sidepods taller.
Williams also has this concept of "ending" it's rear end earlier and more abruptly (for quite a few years now), contrary to most teams that tend to slim it down progressively.
Looking straight from the back this makes them look very fat, but in reality it isn't.
joseff
Thanks Sevach, but the photographer eliminated a lot of image detail to the LOMO filter there.
Francesc
Francesc
50
Asymetric opnenings
George-Jung
George-Jung
stefan_ wrote: Image
Is there a white sticker on the nose?
George-Jung
George-Jung
