I think nobody will now until first GP in 2017, as there are new aero rules, but also the PU development restriction is gone, so depending on how many things PU manufacturers are not doing this season because of tokens restriction we could see a huge jump ahead on some PU manufacturers (what I expect from Honda), or not so much in some others (Ferrari or Renault maybe). I´d like to put Mercedes in the second group considering they have the most advanced PU so they have less to develop, but the technology is still pretty new and they´re doing an awesome job since day 1, so it wouldn´t surprise me if they also make a big step forwardMansell89 wrote:In 2014, 2015, and 2016, F1 has been described as a 'power-driven' Formula.
With these aero changes in 2017- how much does the see-saw come back towards aero influence for lap time?
Does it alleviate the pressure from the likes of Honda and Renault, who have been on the back foot behind Mercedes? Or does the engine still hold a major advantage? Or thirdly- does it further the advantage in that the extra speed exaggerates those engine power differences?
It's an interesting question- drag is going to increase considerably so the teams will strive to find a balance between downforce and lots of drag, not that I am saying that it is one or the other, but lots of drag needs lots of power to overcome it, hence Mercedes using barn door wings vs RBR using skinny wings in 2014 when there was a considerable gap in PU performance. Based on nothing more than a finger in the air I cannot help but feel this will be exaggerated next year.Mansell89 wrote:In 2014, 2015, and 2016, F1 has been described as a 'power-driven' Formula.
Hmmm, I think it will be less actually. The target is always to have the maximum amount of downforce with the least amount of drag. With the new rules, with the new diffuser, the percentage of drag for a certain amount of downforce may acutely go down (but with the steep rise of downforce will go up in real numbers).Gaz. wrote:It's an interesting question- drag is going to increase considerably so the teams will strive to find a balance between downforce and lots of drag, not that I am saying that it is one or the other, but lots of drag needs lots of power to overcome it, hence Mercedes using barn door wings vs RBR using skinny wings in 2014 when there was a considerable gap in PU performance. Based on nothing more than a finger in the air I cannot help but feel this will be exaggerated next year.Mansell89 wrote:In 2014, 2015, and 2016, F1 has been described as a 'power-driven' Formula.
Yes. There will be an large increase in drag, but also a large increase in downforce (wider wings, wider floor due to the increased track) but the big difference is the longer, higher diffuser which gives "free" downforce without a huge extra increase in drag. I think it might be possible with the 2017 cars to increase downforce more then it costs drag.Gaz. wrote:Have you considered the extra width of the tyres and increased track?
With 25% more downforce and similary increased mechanical grip brake forces won´t be as high?skoop wrote: -Brakeforces won't be as high as this year, because of slower straight line Speed
Andy Greens argument is, that you won't brake as hard, because you go quicker in the Corners. This and the slower top speeds will lead - according to him - to reduced brake forces.Andres125sx wrote:With 25% more downforce and similary increased mechanical grip brake forces won´t be as high?skoop wrote: -Brakeforces won't be as high as this year, because of slower straight line Speed
I know if topspeed is lower brake pressuse must be lower as higher speeds provide more DF so they can brake faster, but even so overall grip difference will be massive, and top speed difference will be specially noticeable on long straights, but at any other medium or short straight brake forces should be higher I think.
And even on tracks like Monza they will continue reducing drag as much as possible even if that reduces DF, and that means they might end up with similar DF and drag (even flatter wings), but wider tires will still improve braking and increase braking forces. That´s assuming they can go with similar DF and drag to current cars for Monza stile tracks wich I´m not sure if correct as the car and wings are wider
