McLaren MCL38
f1rules
f1rules
597
Re: McLaren MCL38
Nope lighting playing tricks, you can see here it flat
mwillems wrote:
03 May 2024, 18:07
f1rules wrote:
03 May 2024, 17:54
he looks happy
https://pbs.twimg.com/media/GMqgWnhW8AA ... name=large
This is the pic that tells me that the waterslides aren't gone near the driver, there's clearly an upper edge, it's just more like a spoon than a canal at the top of the sidepods now. Definately not flat.
LionsHeart
LionsHeart
Re: McLaren MCL38
f1rules
f1rules
597
Re: McLaren MCL38
here it is the new - i think ;-)
f1rules
f1rules
597
Re: McLaren MCL38
Re: McLaren MCL38
The new sidepods with the late steep waterslide are similar to the rb20.
They have the scalloped rear sidewall of the sidepod which was first brought by the W14B. To be honest overall it bears lot of resemblance to W14B
Sidepod inlets slightly increased in aspect ratio and with larger midwing/overbite.
Some great details and putting everything together nicely.
f1rules
f1rules
597
Re: McLaren MCL38
new vs old fw. New below. Its in the detail. But, curvature/spoon in the mainplane more flat and longer compared to old version, attachment point tweaked also as well wing elements
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL38
f1rules wrote:
03 May 2024, 19:00
https://pbs.twimg.com/media/GMq1X_ZWIAA ... ame=medium
Looks like the total frontal area of the wing is reduced/tweaked. Possibly due to the front part of the floor generating more DF. therefore you can have a front wing that’s slightly backed off and used more for flow conditioning and less DF generation (and hence less drag)
Re: McLaren MCL38
f1rules wrote:
03 May 2024, 19:00
Yeah main plane is the largest difference I think
f1rules
f1rules
597
Re: McLaren MCL38
new and old car and fw, also notice how much they gained from narrowing the sidepod inlet height and making it wider instead,
LionsHeart
LionsHeart
Re: McLaren MCL38
f1rules wrote:
03 May 2024, 19:00
There are many changes to the front wings. They are all small and insignificant, but I found more than 5 points where there are changes.
If anything, I can highlight it for the general view.
_cerber1
261
Re: McLaren MCL38
SilviuAgo
Re: McLaren MCL38
Explained: McLaren's 'astonishing' 10 upgrades only Lando Norris is running
https://www.crash.net/f1/news/1047790/1 ... is-running
michl420
michl420
19
Re: McLaren MCL38
The new wing is also easy to identify at the different nose tip. (or the light playing tricks)
Holm86
247
Re: McLaren MCL38
michl420 wrote:
03 May 2024, 23:02
No its definitely different, more rounded rather than flat
f1rules
f1rules
597
Re: McLaren MCL38
yep i think you guys are right, updated nosetip
