lol, more likely Mclaren or Ferrari invented sandbagging at least in F1.Owen.C93 wrote:Red-Bull invented sandbagging?
"The first impressions of the car were very positive"Ferraripilot wrote:Both drivers previously stated they were immediately comfortable with W02, which is a great sign considering both were immediately not comfortable with W01.
Why? Can't remember anything relevant.ringo wrote:Their exposure is illegal
It's basically saying that you cant have crash structures out in the open air, and if you try to be smart and put a tube over them to say the external air isn't contacting it, the second part of the regulation ensures closed sections like tubes can't be used to encase the structure.3.8.6 The impact absorbing structures defined by Article 15.5.2 must be fully enclosed by bodywork, such that no part of the impact structure is in contact with the external air flow. When cut by a longitudinal vertical plane, the bodywork enclosing these impact structures must not form closed sections in the region between 450mm and 875mm forward of the rear edge of the cockpit template.
15.5.2 Between the front and rear roll structures, on each side of the survival cell, impact absorbing structures
must be fitted and must be solidly attached to it. The purpose of these structures is to protect the driver in the event of a lateral impact and, in order to ensure this is the case, a lateral strength test in the vicinity of the driver's seating position must be carried out successfully. Details of the test procedure may be found in Article 18.2.2.
