PlatinumZealot wrote: ↑05 Mar 2020, 15:04
Just_a_fan wrote: ↑05 Mar 2020, 13:33
Chene_Mostert wrote: ↑05 Mar 2020, 13:17
This can increase the density of fuel after the FF meter, thus allowing a greater mass of fuel to be stored for a given volume after the FF meter and still comply with the FF rule of 100Kg/h.
There is no cheating the FF meter, and there is no regulation covering this.
Incorrect. The fuel flow rate is limited to 100kg/hr everywhere in the system. If they store fuel after the FF meter, and then flow more than that rate through the injectors (why else do it?), they are breaking the flow rate limit rule.
If the fuel changes properties in order to change the mass flow rate through the fuel system, then it is also in contravention of the following rule as it is a procedure (and indeed a system):
5.10.5 Any device, system or procedure the purpose and/or effect of which is to increase the flow
rate or to store and recycle fuel after the measurement point is prohibited.
Basically,
anything you do to move more than 100kg/hr through the fuel system is illegal.
Not exactly. The fuel flow meter is ultrasonic. It measure speed of particles using the doppler effect. Basically measures volume flow rate and they use a look up table of density with temperature to calculate the mass flow rate. If the density can be increased you can increase the mass flow rate without increasing the volume and as such the flow meter will not detect any wrong doing.
It uses time-of-flight, not Doppler. It measures velocity of the flow, speed of sound and temperature. All this info is then combined with the thermal models of the FFM (which is made of only one metal so to make the model more accurate) and of the fuel (they build it using fuel samples from the teams). Then the mass flow is calculated.
The second FFM cannot be "just before the engine", as some suggested, because it cannot withstand the pressure after the HPP.
The measurements of fuel flow within the injection system are indirect, unreliable and quite easily altered.
Look up the posts here a few months back. FFM possible trickery was discussed to exhaustion, of the topic and of the posters
![Laughing :lol:](./images/smilies/icon_lol.gif)
