What it is this?
[img]http://jorgelizalde.co.uk/ferrrari ... .jpg[/img]
I don't see it so clear on redbull or mclaren
http://twitpic.com/8gygil
Thanks, I can see it now. Still not on this picture though but I believe it's there.Spencifer_Murphy wrote:I've lightened the shadows and increased the midtone contrast (not to much avail unfortunately) but have attempted to highlight where I can see the pull-rod my sandwiching it between two yellow lines.
Hope this helps
Edit: Should also help explain why its so hard to see at first, as the angle is just so, that it sits almost perfectly in-line with the lower edge of the nosecose/monocoque. Being the same colour it blends in nicely...or not so nicely depending on how you look at it
Ah I see!, Yes looking at that pic you can't see it at all. But if it is where I think it is, I think in the first picture it is hidden by the upper wishbone. (angles again lol)TheRMVR wrote:I meant the first picture of the page. You can't see it there, it might be hidden but with that big hole there I thought they might have removed it. I know it would be weird to run a car without, hence my remark.
I think that is because there was suppose to some sort of agreement or understanding between the teams not to pursuit exploiting the exhaust for aero benefit in light of the new rulings.Crucial_Xtreme wrote:Newey is already saying he believes the Ferrari & McLaren exhaust solutions will cause controversy.
Thanks Owen for the larger pic
Thanks, thats very clear. If you take a look at the launch photo's that metal hole was filled with a suspension arm, right in the middle between the arms. Can this mean they have different holes in the chassis to try out different suspension lay-outs?amouzouris wrote:here:
i outlined the arms with yellow and the pullrod with red
The face of Massa says it all. Not happy with the camera on that point of view.Crucial_Xtreme wrote:Here is a good look at the front pull rod suspension. Right click>view image
ferrari is using air-stream from sidepods to direct hot gases from exhaust, while mclaren uses those channels which mechanically redirect exhaust gases.ferrari is 'more legal' in exhaust part of the car, but that doesnt make it legal.beelsebob wrote:What I actually find more interesting there is the camera looking at the graining/degradation on the tyres.
Looking at how it had worked before they cut away the top – I have *no* idea how they thought that would pass the regulations.
What makes it "more legal"?radosav wrote:ferrari is using air-stream from sidepods to direct hot gases from exhaust, while mclaren uses those channels which mechanically redirect exhaust gases.ferrari is 'more legal' in exhaust part of the car, but that doesnt make it legal.beelsebob wrote:What I actually find more interesting there is the camera looking at the graining/degradation on the tyres.
well, FIA's last statement was that they are against any kind of redirecting exhaust flow mechanically. i think that mclaren's exhaust position is illegal.beelsebob wrote:What makes it "more legal"?radosav wrote:ferrari is using air-stream from sidepods to direct hot gases from exhaust, while mclaren uses those channels which mechanically redirect exhaust gases.ferrari is 'more legal' in exhaust part of the car, but that doesnt make it legal.beelsebob wrote:What I actually find more interesting there is the camera looking at the graining/degradation on the tyres.
Neiter is illegal in any way, as long as they keep the exit clear of body work, as far as I see them.
The RB8 exhaust flow is redirected by a mechanical device that moves related to speed*, if you want to be pedantic about it. So it will be interesting to see what turns up on track tomorrow.radosav wrote: well, FIA's last statement was that they are against any kind of redirecting exhaust flow mechanically.
