Red Bull RB9 Renault
beelsebob
beelsebob
85
Re: Red Bull RB9 Renault
wesley123 wrote:
dren wrote:Tight packaging under the sidepods.
It also seems much better organised, you can observe what is what very well. Almost placed together like legos, instead of trying to cramp everything in there what other teams seem to do.
I suspect that there's a certain amount of benefit to cooling here too... Heat sinks for all these electrical components could be placed on the lower side of the air intake.
gandharva
252
RB8 vs. RB9
amouzouris
105
My report on the upgrades introduced by Red Bull during winter testing:
Red Bull ran their version of the DRD (Drag Reduction Device) during the second day of the second and last Barcelona test.
Last year, from Singapore onwards Red Bull raced with their own version of the Double DRS ( http://technicalf1explained.blogspot.co ... ystem.html ). As such devices have been outlawed for this year. Teams have tested passive drag reduction devices, similar to the one Lotus introduced in the summer of 2012. Red Bull’s DRD however is neater than Lotus’.
Near top speed, air will bleed through the vertical duct, breaking up the flow, reducing downforce and subsequently drag. The system is made up of three main parts. The first is the intake which is not apparent, but it is hidden inside the roll hoop. The second is the outlet through which air will flow through at all times which is either below the beam wing are behind the rear crash structure above the diffuser and the vertical duct which blows on the rear wing.
During the third day, the team introduced their major upgrade package which included a new front wing, new nose, and a slightly revised tunnel underneath the coanda ramp.
Red Bull has changed their cascade wing philosophy, as it now curls down to meet the footplate vertically together with the endplate, similar to the way the main profile of the front wing is shaped. Additionally, there are now slots in the endplate to keep the airflow attached. This will improve the way the air flows around the front wheels.
The new nose is now slightly lower, and there is a new vanity panel which is no longer chamfered. The new nose still sports the holes at the bottom and at the top which form the S-Duct (http://technicalf1explained.blogspot.co ... -duct.html).
New Nose
Old Nose
http://technicalf1explained.blogspot.co ... eport.html
bar555
bar555
Red Bull also tested a revised diffuser at Barcelona test on February
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
Forza
238
F1 Australian GP - Friday FP1 - 15/3/2013
Image[/URL]
Edit 1
Edit 2
Different front wing flap it seems
Joie de vivre
Are they still allowed to map the engine or not?
Cam
45
Joie de vivre wrote:Are they still allowed to map the engine or not?
I believe the engine maps must be the same as 2012. No adjustment outside that can occur.
― Socrates
FlYiNgIcEmAn
FlYiNgIcEmAn
Beautiful integration of the DRD, looks good. =D>
Pandabeer
Pandabeer
I read an article that they were allowed to choose an engine mapping from one of the first four races in 2012. First four races because it was before the switch to the banned engine mappings.
Huntresa
Huntresa
Pandabeer wrote:I read an article that they were allowed to choose an engine mapping from one of the first four races in 2012. First four races because it was before the switch to the banned engine mappings.
Yeah cause the directive from Hockenheim is still in play
via Matt Somerfield
Kiril Varbanov
147
Benson on Vettel and RB9 from the track - https://twitter.com/andrewbensonf1/stat ... 8494146560
Matt Somerfield ‏
Red Bull - New Diffuser Gurney, doesn't extend around the sides of Diffuser + Beam Wing hole, reduces drag (not new)
Matt Somerfield
Red Bull RB9 - Excellent shot of the Splitter and Perforated Floor Scroll
