2013 Bahrain GP - Sakhir
Phil
66
Re: 2013 Bahrain GP - Sakhir
Goran2812 wrote:
raymondu999 wrote:
Pierce89 wrote:Blatant disregard? The DRS is supposedly controlled by FIA software to not be allowed to open up outside a DRS zone. You can't blame a software glitch on Ferrari.
That's like saying "cheating is supposedly controlled by the invigorating to not be done during tests. You can't blame that on the student."
Sure the FiA system was broken. But the facts are that Fernando pushed the button where he shouldn't have. To me that leaves one of two possible explanations:
- he (genuinely) didn't remember that the activation was some way down, and just remembered to use DRS "on the pit straight" - in which case you have to wonder if their qualifying lap was then legal.
- he knew he had an excuse to plead memory shortage against the FiA, and knew that he had a get out of jail free card by saying, "how was I supposed to remember?"
If it was on purpose, I believe we can call it, as Cam says, "blatant disregard." If it was a genuine error - then less of the blame (in a moral/ethical sense) on Fernando. But I'm quite sure Vettel in Abu Dhabi 2012 qualifying and Hamilton in Spain 2012 qualifying were genuine underfueling mistakes too.
with all due respect ray, some things you wrote/ "accused" Alonso/Ferrari here are wrong and hold no ground...
I think you're missing the point. This is not about putting blame on someone, but about how to properly deal with when regulations are broken.
The DRS was used outside its intended zone. That's a fact.
Some of it is probably down to the on-site technical requirements not working as they should, thus allowing DRS to be technically used outside the intended zone. So how do you deal with it, if you have a driver that uses it by reflex outside the zone and assumes it's not his problem vs. a driver who only uses it in the intended zone?
If the instruction is "don't use the DRS button/trigger outside the zone", then it is clear that any driver who does exactly that shall be punished. If the FIA did not think about this and assumed that their systems are faultless and that it's impossible that DRS could be used outside the zone and for some reason, a driver is still able to use it, then I guess it's a bit more difficult to police and/or punish it. It's still an unfair advantage though, to those who used DRS correctly.
If you don't deal with this issue, then what is to stop other drivers using it outside the zone and putting it down to reflex or hiding behind the stance 'that it is not their problem/responsibility'?
Think about the implications, i.e. if someone had a defective KERS unit that allowed him to use more than the intended amount within the lap? Should that go unpunished as well? It's easy to deal with errors when they cost time and performance - the big question is, what do you do when an error in the system/car gains an unfair advantage?
In the case of Alonso - over the course of the entire race day, his faulty DRS clearly cost him, so I agree that in this particular case, he shouldn't be punished, even if he did use DRS outside the intended zone while it was working (and there is a rule somewhere that states that drivers shouldn't attempt to use it outside the designated zones). However, if his DRS hadn't ended up breaking, then IMO, you need to police it. Or else you'll have teams designing faulty DRS systems that break in a way to give them some form of advantage eventually during the race.
#Team44 supporter
Kowalsky
Kowalsky
If there is problem only with one car using DRS outside described zones, so investigation should be in place.
If there are any doubts over ability to steer properly DRS launch, so there should be general "DRS disabled" notification for all.
This is not accusing anyone of cheating, this is simply question why driver with failure breaking regulation is driving few laps without any consequences. Because someone says "there was no profit" and it is finished? Holding position is not a profit?
Rikhart
Rikhart
beelsebob wrote:
Rikhart wrote:"epic driving"? :lol:
He was just missing the upper flap of the rear wing,
Except that any DRS these days is designed such that the air will separate from the main plane if the DRS is open, and stall out the whole rear wing. That, plus the fact that it was inverted meant that the rear wing as a whole was generating lift, not downforce most likely. That's a very significant difference.
3 tenths per lap. Thats absolutely nothing, and like I said its ridiculous to call it "epic driving".
beelsebob
beelsebob
85
How have you gone about computing that the rear wing producing lift instead of downforce will cost exactly 3 tenths per lap?
thevlack
thevlack
HAM got a penalty 'cause his tyre broke, and that damaged the Gear box... So regulations (bad or not) were in full effect. It was clearly not a HAM fault...
ALO opened his DRS in a place that is not allowed, and he got not penalty... I dont care if he lost the race or watever the regulation must apply there...
So the maFIA is alwyas choosing which penalty to apply... I'm not sure why I'm surprised by it.
Sorry if this offends anyone. :)
beelsebob
beelsebob
85
thevlack wrote:HAM got a penalty 'cause his tyre broke, and that damaged the Gear box... So regulations (bad or not) were in full effect. It was clearly not a HAM fault...
No, Alonso's DRS was open, Alonso did not open it. The rules specify when the drivers may command the DRS to open, not when the DRS may be open. They do however also specify that the DRS must fail closed, the team should be getting a penalty.
muhammadtalha-13
muhammadtalha-13
-2
Alonso's DRS was open, so its FERRARI's fault. Damage, Reliability whatever you say its their fault and they should have been penalised. Hamilton got a penalty because his gear box was damaged because of a tyre failure. Whose fault it was? PIRELLI's. Then why Hamilton got penalised and not Alonso???
EDIT: And even after first pitstop, he knew his DRS was not working properly, he used it again.
muhammadtalha-13 wrote:Alonso's DRS was open, so its FERRARI's fault. Damage, Reliability whatever you say its their fault and they should have been penalised. Hamilton got a penalty because his gear box was damaged because of a tyre failure. Whose fault it was? PIRELLI's. Then why Hamilton got penalised and not Alonso???
The trouble is that Hamilton wasn't penalised for the damage, but for changing the gearbox.
Ussually the FIA and the stewards are very lenient when it comes to by damaged caused illegal cars. And what's the point of punishing those teams for that? It's not like they intended to run their cars like that.
Very unfortunately for Hamilton that he had to change the gearbox caused by damage. The FIA themselves are bound by their own rules; they had no choice except to apply the penalty. In this particular case it is very unfair, but nothing that there can be done about.
thevlack
thevlack
Yeap, I wrote that wrong, I wanted to say this: The DRS Failed on him, and it was open on parts of the circuit where is not allowed -- So simply as that it should be tied to a penalty to him, as HIM represents the team on the track.. Its ferrari's car, but HIS name score the points to the team.
Is the same on HAMs case, the tyre/Car failed, so the HIM got penalized because with the damaged gearbox you couldnt race.
I'm not a fan of any particular Driver now, (I was a MSH fan) so I just get upset for the diferences that made on when to penalize or not a driver..
Sorry for the FIA reference, it was out of place.
beelsebob
beelsebob
85
Again, the rules do not ban having your DRS open in areas of the circuit other than the DRS zone. They ban activating the DRS in areas of the circuit other than the DRS zone.
Rikhart
Rikhart
beelsebob wrote:
Rikhart wrote: 3 tenths per lap. Thats absolutely nothing, and like I said its ridiculous to call it "epic driving".
No need to compute anything, that´s what he was losing when he had the problem, according to a website I was reading.
SilverArrow10
To be perfectly honest I think that Hamilton's penalty actually helped him. He was in clear air for 2 stints just in that gap between the top 6 teams and the rest. Being there meant that he didn't have to make a fourth stop because during the first half of the race because Rosberg was defending hard and ruining his tires, Hamilton was having a nice drive out in clear air. He may not have deserved the penalty but I doubt he's complaining, and neither am I.
beelsebob
beelsebob
85
Okay, and how did they calculate it? How do they know that he wasn't losing about 6 tenths worth of performance from the car, but driving epically to keep it on the road?
ForzaFer
I made a small test in my f1 simulator. I first drove with standard setup for bahrain(rear wing angle 32) on race fuel(i fill 195 litres in tank) on medium tyres and average on first 10 laps was 1:34.5 and after that i filled tank again but instead of rear wing 32 a made it be 6 to simulate DRS failure on Ferrari. Average time first 10 laps 1:36.4. (+1,9 sec)
So though this isn't of course real world it can provide some kind of information. Well, it's such a huge loss of downforce so anything gained on straights is nothing compared to losses in corners. Sorry for little off-topic
Goran2812
Goran2812
27
logical thing to believe is the premise that all systems are functioning normally in the race (up to the point when you realize that something f**** up and is not working). That means all systems controlled by ferrari and all systems controlled by the fia... yes, they have a designated drs zone, and they have a system that limits the flaps to that zone. if the fia system is broken, that's the fia's problem. as we could see in the onboard, on this occasion it was broken... on the other hand the flap also failed, and that was ferraris problem. it took them how many laps, 2-3? to assess the situation, and they called him in. the end... :) the fact they let him open his drs again is plain idiocy on their behalf, and the second stop was a punishment on it's own... :D no need for bashing or developing stories that it was done on purpose or smth like that :D
Visit my photo page! -> http://www.gorankphoto.com/formula1
