So it is okay to pour in millions of $$ on something that is irrelevant?Cold Fussion wrote: ↑16 Aug 2017, 17:19Competition is about beating your opponents by being better than them at the task of hand. Balance of performance is more akin to a cartel to allow manufactures to enter in any old rubbish into a series and have it be competitive. Imagine how ridiculous it would be if Chris Froome had to ride with BOP ballast because he is naturally too gifted an athlete, or Usaine Bolt had to start on a delayed starting gun. What's more, it isn't even good for viewer engagement. Think of the story lines we have in F1 this year, after years of Mercedes dominance, Ferrari finally have a car capable of taking the fight to them, with a driver who once piloted the previous dominate car and was always characterised as not being a racer and only capable of wining with the best car.
Because F1 is a real sport it is capable of producing greatness, with all that is to be celebrated in it. Think of Bolt's dominance of track sprinting the last decade, Froome's dominance of the Tour since 2012 and how they rightfully plauded for their greatness. In a BOP series like GT racing, none of this is possible because true greatness is not possible, it's all about the BOP 'lottery' and gaming the system.
You just literally described exactly what F1 is about. Spending tons of $ for nothing more relevant than the chance to win the prize.FW17 wrote: ↑16 Aug 2017, 18:46So it is okay to pour in millions of $$ on something that is irrelevant?Cold Fussion wrote: ↑16 Aug 2017, 17:19Competition is about beating your opponents by being better than them at the task of hand. Balance of performance is more akin to a cartel to allow manufactures to enter in any old rubbish into a series and have it be competitive. Imagine how ridiculous it would be if Chris Froome had to ride with BOP ballast because he is naturally too gifted an athlete, or Usaine Bolt had to start on a delayed starting gun. What's more, it isn't even good for viewer engagement. Think of the story lines we have in F1 this year, after years of Mercedes dominance, Ferrari finally have a car capable of taking the fight to them, with a driver who once piloted the previous dominate car and was always characterised as not being a racer and only capable of wining with the best car.
Yes, let's allow them to use a 3l NA engine or a 1.6l turbo.AMG.Tzan wrote: ↑16 Aug 2017, 14:51Why not go back to the 80s formula where you can either have a 1.6 turbo or a 3.0 normally aspirated engine? That way everyone is going to be happy! Both manufacturers like VW can build road relevant turbo engines and manufacturers like Ferrari or smaller manufacturers like Cosworth can build normally aspirated V8,V10 or V12s! Ok there would be some balance of performance needed between the engines but after some years i think they will get it right!
Indeed, the 'official' FIA swept-volume fractional-compensation formula would need urgent revision..wuzak wrote: ↑17 Aug 2017, 04:10Yes, let's allow them to use a 3l NA engine or a 1.6l turbo.AMG.Tzan wrote: ↑16 Aug 2017, 14:51Why not go back to the 80s formula where you can either have a 1.6 turbo or a 3.0 normally aspirated engine? That way everyone is going to be happy! Both manufacturers like VW can build road relevant turbo engines and manufacturers like Ferrari or smaller manufacturers like Cosworth can build normally aspirated V8,V10 or V12s! Ok there would be some balance of performance needed between the engines but after some years i think they will get it right!
Balance of performance is the fuel flow rate, which would be fixed and remain the same for both.
See how many NA engine makers there are then.
Zero!wuzak wrote: ↑17 Aug 2017, 04:10Yes, let's allow them to use a 3l NA engine or a 1.6l turbo.AMG.Tzan wrote: ↑16 Aug 2017, 14:51Why not go back to the 80s formula where you can either have a 1.6 turbo or a 3.0 normally aspirated engine? That way everyone is going to be happy! Both manufacturers like VW can build road relevant turbo engines and manufacturers like Ferrari or smaller manufacturers like Cosworth can build normally aspirated V8,V10 or V12s! Ok there would be some balance of performance needed between the engines but after some years i think they will get it right!
Make the N/A engines 4.8l (3:1, as was the case for supercharged to N/A engines in 1950) or 6.4l (4:1), or even 8l (5:1). I doubt it would make much difference to how many manufacturers chose a N/A engine under a fuel flow formula.J.A.W. wrote: ↑17 Aug 2017, 05:51Indeed, the 'official' FIA swept-volume fractional-compensation formula would need urgent revision..
with any capacity ratio of N/A to F/A value-adjusted to reflect the inherent difficulty/cost of overcoming
4T engine 'lazy' torque out-put at atmo pressure,accounting for technical progess..
Since as was indicated by the previous F1 N/A mills, spinning up those prodigious rpm needed to compensate.. is clearly a 'diminishing-marginal-return' game.. in mechanical reality..
Nothing I said precludes F1 from using road relevant technology.FW17 wrote: ↑16 Aug 2017, 18:46So it is okay to pour in millions of $$ on something that is irrelevant?Cold Fussion wrote: ↑16 Aug 2017, 17:19Competition is about beating your opponents by being better than them at the task of hand. Balance of performance is more akin to a cartel to allow manufactures to enter in any old rubbish into a series and have it be competitive. Imagine how ridiculous it would be if Chris Froome had to ride with BOP ballast because he is naturally too gifted an athlete, or Usaine Bolt had to start on a delayed starting gun. What's more, it isn't even good for viewer engagement. Think of the story lines we have in F1 this year, after years of Mercedes dominance, Ferrari finally have a car capable of taking the fight to them, with a driver who once piloted the previous dominate car and was always characterised as not being a racer and only capable of wining with the best car.
Is that an "educated best-guess" Wayne?wuzak wrote: ↑17 Aug 2017, 06:19Make the N/A engines 4.8l (3:1, as was the case for supercharged to N/A engines in 1950) or 6.4l (4:1), or even 8l (5:1). I doubt it would make much difference to how many manufacturers chose a N/A engine under a fuel flow formula.J.A.W. wrote: ↑17 Aug 2017, 05:51Indeed, the 'official' FIA swept-volume fractional-compensation formula would need urgent revision..
I am not talking of turbo-compound engines, but the (likely) 2021 twin turbo V6s.J.A.W. wrote: ↑17 Aug 2017, 07:22Is that an "educated best-guess" Wayne?wuzak wrote: ↑17 Aug 2017, 06:19Make the N/A engines 4.8l (3:1, as was the case for supercharged to N/A engines in 1950) or 6.4l (4:1), or even 8l (5:1). I doubt it would make much difference to how many manufacturers chose a N/A engine under a fuel flow formula.J.A.W. wrote: ↑17 Aug 2017, 05:51
Or have you seen the predictive thermodynamic physics/maths - that deem it a 'lay down misere/dead-cert'..
for the turbo-compound machine..
Maybe if weight minimums were relaxed for N/A racecars too, then they'd get to compete on race-speed..
There ought to be a power-to-weight trade-off continuum there.. somewhere, surely?
