Aston Martin Red Bull Racing TAG Heuer RB14
Re: Aston Martin Red Bull Racing TAG Heuer RB14
tok-tokkie
tok-tokkie
38
How are the bell cranks manufactured?
The two pieces with the centre spring between them. I assume they are lost was castings.
Maritimer
Maritimer
19
tok-tokkie wrote:
24 May 2018, 18:43
https://uploads.tapatalk-cdn.com/201805 ... 0ec078.jpg
5 axis mill? Probably starts out as a rough cast though.
Maybe even sintered, then machined for tolerances only?
tok-tokkie
tok-tokkie
38
I see no trace of machining marks on those bell cranks which is why I suggested investment casting.
Sieper
73
RBR is this year also investing in tidying up all these components, like the fluid reservoirs posted some time back, no generic of the shelf containers and tie wraps but a specially formed (injection molded) reservoir. Molds have been cut specially to be able to do that, costs quite some money.
e36jon
e36jon
66
tok-tokkie wrote:
24 May 2018, 18:43
My money is on CNC of billet material. A casting, by any method (investment, pressure, die) will always have the risk of porosity & inclusions. For parts this small and highly loaded you need to start with material that has impecable qualities, hence billet. Regarding 'no visible machining marks' it is common on highly loaded parts to do handwork to polish the surface and then do a shot-peened finish. I have a Pankl con-rod that has the same production path as I am suggesting they used here...
tok-tokkie
tok-tokkie
38
Shot peened. Now that would explain the surface finish. I accept what you say about billet strength vs cast.
AngelicPrincess
AngelicPrincess
Bell cranks are normally made of Ti, rough machined and stress relieved, then further machined to a Ra 0,8 surface finish. And as said above shot peened. Hence the lack of machining marks. Surface finish on a highly stressed component is extremely important to prolong life.
While I am at it, it is not unsual to see hudraulic conponents such as the power assisted steering rack have a golden look. That is TiN (Titanium Nitrate) coating for corrosion resistance.
Can you brighten the bottom image so that the bargeboards can be seen? For science.
AngelicPrincess wrote:
25 May 2018, 19:12
Must cost a fortune, just the raw materials are expensive, but the machining costs. Well at least to mere mortals like myself, goes to show the craftsmanship and dedication every component is built with. It's really a shame that so many technical details are hidden behind bodywork, and stationary photos.
AngelicPrincess
AngelicPrincess
godlameroso wrote:
25 May 2018, 21:53
25 May 2018, 19:12
Yes very very expensive, but this is f1. I wouldn't call it craftsmanship. Nowadays the designer produces the CAD drawings to extreme detail, another one does the tool path programming and a machinist sets it up and presses go. they try to eliminate the human factor when manufacturing as much as possible, we humans just introduce inaccuracies, and in a world where everything runs to very tight tolerances thats unacceptable.
Ironically enough humans still have to check over the finished product for defects which machines/material quality still occasionally make.
roon
roon
412
Humans still write software. I think there might be more to the machinist's job than pressing a big green button on the 5-axis.
