Distomak wrote:Hi all, I'm new here, hope this is a friendly forum
I was watching a program on Formula One a while ago, and a designer said that Formula One cars were like jet engines, but they are pointing down onto the track to create downforce instead of upwards to create lift.
On hearing the rumours of a secretive Ferrari front-wing config, I brainstormed an idea for a wing based on the theory that if you lift a wing on an airplane [or a jet...], the plane will turn in the opposite direction.
My theory is therefore that if the front wings were fitted with hydraulic lifting devices to make them lift upwards, this may mean that formula one cars could go into corners at much greater speed - as they would be using the current force of the engine rather than slowing down and building up again.
I have scanned over the FIA Rules for relevant sections, and here are the areas which I thought a team may be able to use as a loophole for such wings.
3.14 Overhangs:
No part of the car shall be more than 500mm behind the centre line of the rear wheels or more than 1200mm in front of the centre line of the front wheels.
No part of the bodywork more than 200mm from the centre line of the car may be more than 900mm in front of the front wheel centre line.
All overhang measurements will be taken parallel to the reference plane.
3.15 Aerodynamic influence:
Any specific part of the car influencing its aerodynamic performance (with the exception of the cover described in Article 6.5.2 in the pit lane only) :
- Must comply with the rules relating to bodywork.
- Must be rigidly secured to the entirely sprung part of the car (rigidly secured means not having any degree of freedom).
- Must remain immobile in relation to the sprung part of the car.
Any device or construction that is designed to bridge the gap between the sprung part of the car and the ground is prohibited under all circumstances.
No part having an aerodynamic influence and no part of the bodywork, with the exception of the skid block in 3.13 above, may under any circumstances be located below the reference plane.
Therefore, 3.15.3 [Rigidity] clears this device for use. If a hydraulic actuator is used to control the wing movements, then it could be argued that, while in the event of a system failure the wings would be open to malfunction, this would only be the same amount of failing as another piece of bodywork falling off.
Also, in reply to 3.15.4, the front wing's movements are immobile in relation to the sprung part of the car - in simple terms this means that will the part wobble, and obviously, it won't.
