I'll share my two cents, although I won't label myself "aero guy":Crucial_Xtreme wrote: @Shelly Pierce or any of the other good aero guys:
What do you think about the Valencia aero updates? Namely the bargeboard vortex generators & the new scoop on the floor? How do you see these interacting with the air?
I thought we may see McLaren style VG's on top of the sidepods but there is two VG's by the mirrors which has been modified on Fernando's car to include the mirror mounting. What say you about this update as well? TIA.
1. The bargeboards design is certainly made in conjunction with how the flow interacts behind. From the two pictures I've seen it looks like the they worked exactly as expected - the flow-viz pattern was really smooth and predictable.
Note: the extensive use of flow-viz is a bit of sign for re-assurance of the CFD flow, especially on such elements which can be tested rather predictably.
2. The scoop which is mid-way through the floor - it has been introduced in Valencia, in Canada I'm absolutely sure that the floor was flat in that area.
The purpose of such design would be twofold:
2.1. to prevent the tire squirt, as the usual three slots ahead of the tires are not present in Valencia
2.2. to direct air under the sidepod (more inboard) and subsequently merge it with the flow coming from exhausts above. The design itself resembles the two consecutive shark fins on the side of the driver. The mirrors were also mounted ahead of those fins and I'm sure the move has its merit.
