Ferrari F2012
Forza
238
Re: Ferrari F2012
F2012 suspension detail
radosav
radosav
Re: Ferrari F2012
Gridlock wrote:
radosav wrote: well, FIA's last statement was that they are against any kind of redirecting exhaust flow mechanically.
The RB8 exhaust flow is redirected by a mechanical device that moves related to speed*, if you want to be pedantic about it. So it will be interesting to see what turns up on track tomorrow.
Anyone at Jerez care to see which garage burns the midnight oil longest? :D
How much Red Bull is there at Red Bull? :?
*the upper wishbone sits right in it
i know that, but FIA changes their regulations without defining it strictly. last change was two days ago abut exhaust and front wings .
mx_tifoso
mx_tifoso
Re: Ferrari F2012
I suppose that teams will take it as far as they can before being protested or contacted by Charlie Whiting. I don't see why they wouldn't.
And lol at the disappearing front pull rod.
Spencifer_Murphy
Re: Ferrari F2012
mx_tifoso wrote:And lol at the disappearing front pull rod.
:lol:
mx_tifoso wrote:I suppose that teams will take it as far as they can before being protested or contacted by Charlie Whiting. I don't see why they wouldn't.
Of course, thats what F1 technology is about isn't it? The designers make the cars go faster, the FIA slow them down (usually in the interests of safety) again with regulations, then the designers come up with new and inventive ways to circumvent these rules.
Its an epic, and never ending power struggle. lol
Silence is golden when you don't know a good answer.
volarchico
volarchico
Re: Ferrari F2012
Redragon wrote:Also I am seeing this on this picture. A second exhauts from the radiators and some holes recapturing this hot air to direct on the central back or I am just crazy
That is an interesting little pipe going into the crash structure. An exit for hot gases or a conduit for hydraulics for the DRS?
mx_tifoso
mx_tifoso
Re: Ferrari F2012
TheRMVR wrote:
amouzouris wrote:here:
i outlined the arms with yellow and the pullrod with red
Thanks, thats very clear. If you take a look at the launch photo's that metal hole was filled with a suspension arm, right in the middle between the arms. Can this mean they have different holes in the chassis to try out different suspension lay-outs?
I doesn't seem like it was ever filled in.
http://f1tcdn.net/gallery/var/resizes/F ... 70_new.jpg
This pic isn't as clear but you can still see the gap between the pull rod and red body work. IMO.
TheRMVR
Re: Ferrari F2012
What about these pictures. It looks like it's a different place from the pullrod on the track.
I know the angle can play tricks but if you compare it with this picture it just seems a bit strange..
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Ferrari were testing different suspension anchors today. Hence the reason for the confusion. right click>view image
bhall
bhall
244
Re: Ferrari F2012
Between this and the "transparent" engine cover, I'm thinking a course in perspectives might be in order. #-o
230
Re: Ferrari F2012
the side pod radiator exhaust can't influence the engine exhaust, it's simply to slow and low quality energy.
I don't see the illegality in any of the designs. Suspension arms aren't body work no?
bhall
bhall
244
Re: Ferrari F2012
10.3.4 Non‐structural parts of suspension members are considered bodywork.
Does that make any heat shielding bodywork?
Moanlower
Re: Ferrari F2012
I wonder how much flex these flaps have and if this could be a loophole to the flexwing rules?
Here's a large version if this pic. http://f1.f-e-n.net/images/f1/2012/2012 ... 01_tst.jpg
Edit: Looks more like cams from this view
Losers focus on winners, winners focus on winning.
raymondu999
Re: Ferrari F2012
Aren't those a mandated spec part? Those are the camera pods.
失败者找理由,成功者找方法
Mr.G
34
Re: Ferrari F2012
Moanlower - thats because they are cams:)
However, one pic from pit. Just highlighted probably cooling inlet. Maybe for KERS.
Crabbia
Crabbia
Re: Ferrari F2012
just thinking something about the front pull rod. I suspect we will see this fron pullrod again next year. if you look at the ridge after the ramp in the nose its completely clear. next year when the tub height gets pushed down to the same as the nose heightit should actually be even easier to implement front pullrod. i dont know if it will be viable or still possible to fit all the internals in but as far as where the suspension arms and pull rods connect to the tub it looks like they could use pull rod again next year.
long story short maybe they did it thinking that this was going to be their design path for the next few years.
A wise man once told me you cant polish a turd...
