Aston Martin AMR24
abhi1200
abhi1200
Re: Aston Martin AMR24
more pic rear Side with Beam Wing
Front View
abhi1200 wrote:
18 Oct 2024, 12:37
https://i.ibb.co/XVCpdXB/rear.jpg
Front View
https://i.ibb.co/N9Psb4X/front.jpg
Notice the paint on the front wing, when there wasn't in the past...taken some weight off the rest of the car so that now they can comfortably put paint on ?
They've changed the shape of that side pod at the back .... I drew straight red lines to show the curvature difference.
RedNEO
30
diffuser wrote:
18 Oct 2024, 15:02
https://i.ibb.co/86fBCHs/old-vs-new-floor.jpg
Yes I noticed that too. Let’s see what other changes we can spot
I drew a red line on the right of the sidepod to show a ridge and that the section to left of that ridge is lower.
They've also kept that flair out that used to be at the front to the very back near where the red line ends and that purple dip starts. It's much less pronounced though.
issey
issey
diffuser wrote:
18 Oct 2024, 14:50
abhi1200 wrote:
18 Oct 2024, 12:37
Front View
The added livery on the FW is part of the generation 3 campaign.
Luscion
Luscion
99
KimiRai
KimiRai
258
SSJ4 wrote:
18 Oct 2024, 12:08
interesting that they have reverted back to cut/hole in floor edge. like during this season and last year
That type of cutout in the floor edge was introduced in Austin 2023 I believe and maintained for the launch spec AMR24, then removed with the Suzuka package and now reintroduced with this year's Austin package :lol: Interesting that they've brought it back
Suzuka 2024 (removed)
Austin 2024 (introduced again)
Strange, they have the front a rear suspension circled but I see no reference to it.
Luscion
Luscion
99
diffuser wrote:
18 Oct 2024, 18:23
i messed up and posted the one for Mclaren, fixed it with the right one
SSJ4
SSJ4
25
KimiRai
KimiRai
258
New front wing. It looks like they have removed the notch introduced at Imola. Main plane has changed too
Inlets look slightly different or is it camera angle? They seem smaller
Old
SSJ4
SSJ4
25
Would be cool to see people’s opinion on this
SSJ4 wrote:
19 Oct 2024, 13:34
Top side surface of wings is not very interesting to check, nothing extraordinary can happen there since the pressure build-up forces the air upon all surfaces and through channels. Top side surfaces are sprayed and brush-painted with flow viz so it reaches underside of the next flap, which is what teams are most often looking at. In this case, there is fairly clean flow viz pattern on top side near the endplate, meaning they wanted to check this area. Flaps near the nose weren't interesting on top side as far as I can tell
AeroGimli.x
KimiRai
KimiRai
258
