McLaren MCL38
Marc.W
26
Re: McLaren MCL38
Stu wrote:
05 May 2024, 10:18
I find this shot intriguing!!
I seem to be seeing three lower wishbone arms…
Is the front lower arm is the steering arm and the rear two arms a very narrow wishbone? (Kinematically & structurally this would seem very non-optimal).
Is the front (upper) of the two rear (lower) arms the steering arm? (Ergonomically this seems very non-optimal - putting the drivers’ family jewels in very close proximity to a directly linked wheel/rack!)
Three pivots just doesn’t work!
Great idea for aero conditioning though!
They moved the rack from in front of the lower wishbone to behind the lower wishbone
venkyhere
venkyhere
Re: McLaren MCL38
This is now Ackerman steering :D with steering rod 'behind the axle line'.
Jokes apart, in what way does it influence the assembly / repairs / adjustments to be done in the paddock ? easier/harder/nodifference ?
Stu
Re: McLaren MCL38
Marc.W wrote:
05 May 2024, 11:19
Stu wrote:
05 May 2024, 10:18
Thank you! I had forgotten that, steering column does look ‘close’ to driver anatomy!
michl420
michl420
Re: McLaren MCL38
Yeah, I also thought that there must be a mechanic steering column to the cylinder and it would be probably between the drivers leg, which would be odd.
f1rules
f1rules
621
Re: McLaren MCL38
One have to admire the non-size gearbox, incredible the compactness
Emag
Emag
108
Re: McLaren MCL38
f1rules wrote:
06 May 2024, 10:42
https://pbs.twimg.com/media/GM4gtVCXoAA ... name=large
McLaren makes those on their own. Glad to see them have this level of independence, unlike the other Mercedes customers. This car didn't look that different on the flesh when compared to the final spec MCL-60. But clearly, a lot of work went under the hood to make the platform that much better.
Developer of F1InsightsHub
LionsHeart
LionsHeart
Re: McLaren MCL38
f1rules wrote:
06 May 2024, 10:42
I've been looking at this photo for a couple of days now and I can't shake the feeling that the area where the air flows accelerate the most, the area where the center with the minimum pressure is located, has moved back closer to the rear, closer to the diffuser area. Perhaps thanks to this, it was possible to stabilize balance and controllability. Or this is a primer for further improvements.
But everything looks exactly like this: the pressure gradient under the floor and the center of gravity of the chassis have become much closer to each other in relation to the longitudinal axis.
Stu
Re: McLaren MCL38
f1rules wrote:
06 May 2024, 10:42
Interesting little detail at the rear of the diffuser, a change in roof height towards the outer edge to encourage outwash (working with the lower vanes on the rear hub).
SSJ4
SSJ4
27
Re: McLaren MCL38
mwillems
45
Re: McLaren MCL38
mwillems wrote:
03 May 2024, 17:46
Yes it is definately tighter all round, increasing the airflow to the wing and diffuser, on top and underneath the sidepod.
Is it wider by a little?
Turns out the bodywork is a little wider. This is why the undercuts are waterslides are deeper/wider. It'll also be helping with that dirty air, particularly at the low speeds.
-Bandit
SiLo
139
Re: McLaren MCL38
Stu wrote:
07 May 2024, 12:24
f1rules wrote:
06 May 2024, 10:42
I drew this up before I saw your comment but yes, that was the most interesting part or me after the incredibly small gearbox underside.
Felipe Baby!
mwillems
45
Re: McLaren MCL38
SiLo wrote:
07 May 2024, 14:14
Stu wrote:
07 May 2024, 12:24
f1rules wrote:
06 May 2024, 10:42
https://i.imgur.com/okwhyo5.png
It's at the exit where I have put the scrawled red arrow, I think
-Bandit
Stu
Re: McLaren MCL38
mwillems wrote:
07 May 2024, 14:24
SiLo wrote:
07 May 2024, 14:14
Stu wrote:
07 May 2024, 12:24
https://i.ibb.co/1bvxZMt/Diffuser.png
Yep, that’s the bit that I was seeing.
ANDY238
ANDY238
19
Re: McLaren MCL38
Re: McLaren MCL38
Size Zero Is Back...
