As gran would say WHAT a load of old --- lolRaptor22 wrote:marcush. wrote:in all honesty ,the engine cover is difficult ? in what ? perhaps in getting into the small autoclave they have ..n smikle wrote:I don't know my self but the way Ken Anderson of USF1 makes it sound, the engine cover seems to be one of the more difficult parts to make. I guess that is why the Lotus' has such a simple shape.![]()
If you can make a tub , nosecone ,wings and suspension you should not have a problem with a big panel ...
but wait, we have only seen pieces of the tub yet, maybe he forgot that those items need to be done as well before may15 ,2010...
the engine cover is actually quite a difficult part to manufacture. It needs to be shaped over a wooden plug much like a racing yachts hull.
the complex shapes and size makes this quite a difficult part plus it has to be pretty light hence the skin is thin.
When removing it from the plug extreme care has to be taken or you could end up breaking it and then you have to start from scratch.
The tub is easier in that its made from two halves that are then joined together and co cured in the clave.
The current Lotus was designed with not knowing what engine it will run with.marcush. wrote:http://www.autosport.com/news/report.php/id/81930
in the interview Gascoyne states lotus had no information about cooling figures when designing the cars layout for the sidepods..
How did the other teams using cosworth handle this situation? I can´t believe they had no info either ,and does this hint at lotus originally planning with a generic engine,maybe toyota?
The story does not really make sense to me as something like the cooling needs is a
must have for the design of a lot of parts...looking at the williams ...could it be they also had some data not matching up with reality?
F1 engines are more fuel efficient than a toyota hybrid prius its the downforce that kills the mpgmarcush. wrote:the current range of F1 engines all have a common bank angle ,cylinder count ,weight ,lots of specified things coming with them with rpm as well...
so to even think the cooling demands could vary a big deal is making me ask myself ,how this could possibly be ?
We have the same output or nearly so with all the powerplants ,so lets assume this is in a ten percent range so it is 70 horses we speak about.
In general a IC engine does not use the fuel very efficiently and so the question is
would it be possible to improve on the 32% of heat you put into the water and oil system by a big margin ,or would it be possible someone build an engine that is
up to the task in terms of power but not in terms of heat put into the coolant?
so this would need to use more fuel to produce all that heat ..
I doubt the the cooling demands vary a great deal between engines as they all share a common set of constarainst and knowledge.We are not seing a lot in terms of powerdifference so we see as much in terms of heat then.
but of course one thing remains .They did deliver ,where others struggled and failed ,so credit to them! i just feel this blabla is not necessary as they deserve respect anyways.
Almost a repeat of last year for him then...nacho wrote: Heikki says the balance of the car is pretty good. They just need more downforce and grip.
