He said Lotus actually calls it the "F-duct".
http://motorsport.nextgen-auto.com/Lotu ... 46779.html
hate to be that guy...but i told you so
So this is confusing. I know DDRS will be banned for next year, but the lotus system is not handled by the DDRS. Are there talks about a ban on passive systems?nextgen auto article wrote:And amid suggestions the entire concept will be banned by the FIA for 2013, technical boss James Allison believes it is still worth the investment and effort now.
"(Even) If it goes away next year it’s still something we think is worthwhile putting our effort into," he said.
The last few years rules where generally added to stop teams going against the spirit of the rules. What we have here is something that is nowhere going against the rules. FIA isn't showing, on a noticable level atleast, any intend to hammer down passive systems. The only exception was the passive ride height suspension of Lotus.godlameroso wrote:No it's just that one team is innovating something because there are no regulations regarding internal aerodynamics, and now everyone(administrative entities) is going to the deep end to invent some way to control that. You know, because they rather spend the money on parties n motor-homes than make the cars go a bit faster, and throwdoubt on the bookmakers.
I wondered if the V's were related to the wing fence. That fact that they extend the fence around the end of the wing. If the end of the wing is up against a boundary set by the rules, a V section would allow a fully extended fence while a majority of the end on the wing stayed on the boundary.gato azul wrote:so coming back to the Lotus wing for a bit, someone said that they (F1 teams) use a V-shaped cut out in the top of the flapto "reduce drag".
Yes, that is a valid thought & possibility, but I don't think that this applies in this case - so close, but no cigar - Sorryhardingfv32 wrote: I wondered if the V's were related to the wing fence. That fact that they extend the fence around the end of the wing. If the end of the wing is up against a boundary set by the rules, a V section would allow a fully extended fence while a majority of the end on the wing stayed on the boundary.
Brian
Are they used continuously? Otherwise they could be some simple form of balancing (at the point where rear wing development is nowadays they need new endplates for different AoAs, or are they "universal" despite their heavy sculpturing).hardingfv32 wrote:Yes, I forgot that the slot gap separator is free of the RW dimension restriction. The incident with Ferrari comes to mind know. I wondered why the Lotus leading edge was not sunken.
The discussion of the V on the second element: Are we trying to find drag reduction without downforce reduction?
Brian
I deduced this pages ago as well.issues4 wrote:On British broadcaster Sky’s ’F1 Show’, television pundit Ted Kravitz explained that - unlike Mercedes’ pioneering device - the Lotus version is in fact not attached to the rear wing DRS.
Could the V on the second element be generating a counter rotating vortex to weaken the end plate vortex?gato azul wrote:....the V is cut for another reason.
Someone said, that it was cut to reduce drag somewhat, let's see if we can find the reason, why this is/could be the case, that will bring us closer to the "final" answer.
Hello, there. You are new I see. If did what you said, I would get banned for being "disrespectful" like I was before in double diffuser saga back in 2009.Cam wrote:Pity. My faith in F1 Technical is quite strong when I see fact based posts and posts that add value. My faith in individuals however is somewhat waivering. No-one asked you to take the information supplied as gospel. You should question it. Question everything. This is the exact place to do that - an open and vibrant F1 community. It was posted here as it was relevant to the topic, not necessarily as it was 100% accurate. Thats for us to discuss.n smikle wrote:THanks Harding +1.
My faith in f1 technicaL has dropped emensly. A TV pundit!
Target the information, not the forum where it was posted.
You're really going to mess these guys' heads with boat related stuff like this, the next one related to aircraft suits the case better since you can just disregard the mach 1+ section.gato azul wrote:![]()
gato azul wrote:
Your're not happy. If you're not happy, leave. Don't whinge and complain about it not being what you want. If you want 'your vision', go start your own forum.n smikle wrote: My faith in f1 technicaL has dropped emensly. ... is just making the site boring for me..
not sure where you get the idea from, that it was about boats, just because it says wetted area and wake, does not meanrjsa wrote: You're really going to mess these guys' heads with boat related stuff like this, the next one related to aircraft suits the case better since you can just disregard the mach 1+ section.
