McLaren MCL35M
BrunoH
BrunoH
Re: McLaren MCL35M
is the Mclaren exhaust covered with carbon fibre?!?!?
Herr_Koos
Re: McLaren MCL35M
BrunoH wrote:
15 Mar 2021, 14:17
Why would you think that?
Emag
Emag
84
Re: McLaren MCL35M
BrunoH wrote:
15 Mar 2021, 14:17
Carbon Fiber resists temperatures around 200 celsius.
Exhaust Gasses can reach temperatures upwards of 600-700 degrees Celsius.
You can't use Carbon Fiber for your exhaust even if you wanted to.
BrunoH
BrunoH
Re: McLaren MCL35M
yes i know.. hence why i was so surprised... i was looking at the photo of scarbs from danys car with the radiator... and it looks like the exhausts are covered by carbon fibre... im confused...
Its the one on page 36 of this thread. you dont see the exhausts and it ´´ looks like´´ its got some carbon fiber cover
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL35M
this does not belong in this thread. Baseless speculation and totally pointless. Please take it elsewhere
Re: McLaren MCL35M
101FlyingDutchman wrote:
16 Mar 2021, 10:26
Correct, posts regarding general performance predictions have been moved to the team thread.
Ground Effect
Ground Effect
Re: McLaren MCL35M
Was there any confirmation (pictures) that McLaren trialled more than one floor version?
Re: McLaren MCL35M
Ground Effect wrote:
16 Mar 2021, 12:26
https://www.youtube.com/watch?v=S45-Tff ... el=THERACE
At 7.33 Min
Ground Effect
Ground Effect
Re: McLaren MCL35M
mclaren111 wrote:
16 Mar 2021, 12:54
16 Mar 2021, 12:26
At 7.33 Min
Thanks for this...
f1rules
f1rules
597
Re: McLaren MCL35M
from mclaren, a decent amount of rake i have to say, just saw a test round up video through the mclaren app and there they mentioned they did indeed test the complete car as i understand on the AVL test rig/dyno in Austria for 3-4 days
https://pbs.twimg.com/media/Ewl_3YtW8AU ... =4096x4096
SmOgER
SmOgER
Re: McLaren MCL35M
f1rules wrote:
16 Mar 2021, 20:25
They definitely have quite considerable rake.
f1rules
f1rules
597
Re: McLaren MCL35M
simple photoshop meassure and they are running around 1.9-2.1° rake angle, im not judging if its good or bad or anything, im maybe just a bit surprised with their longer floor this year. I quess if they can seal it, its a positive sign, and the rear definitly looked ok during testing. I need to check compared to last year, but the reason they "may" be running more rake can be to make the front end stronger. Checo mentioned how insane the rb cars frontend are, likely as mentioned by many, due to the fact, that the more rake the closer the fw gets to the ground and the more effctive it becomes
Sieper
73
Re: McLaren MCL35M
I think the bottom green line is a bit misaligned (but as you said, just a simple look) aft it stops shy of the center and is already kissing the yellow, front it stops at the centerline and still is below the yellow band, so it might even be a tad more. But is car perpendicular to camera, is it braking, etc. All influence the rake angle.
Will be interesting to see, McL seems to have the most rake from all merc engined teams.
_cerber1
261
Re: McLaren MCL35M
Herr_Koos
Re: McLaren MCL35M
_cerber1 wrote:
17 Mar 2021, 20:11
https://ibb.co/vLC48T4
Great angle. Car looks like a bullet!
