djos wrote: ↑24 Feb 2022, 04:12
You aren’t wrong, however when you know what helps a driver go faster (and both drivers have said they like similar qualities), you can engineer those qualities into the car. It’s not just aero, it’s a combination of the aero and suspension and how they work together.
Mclaren have been very open about their 21 car having deficiencies in certain areas that lead to it being great at some tracks and terrible at others.
To improve the car, you need to take on feedback from experienced drives like Daniel to produce a more well rounded car that is fast across a wider range of track types.
Engineers don’t drive the cars, drivers do. You can design and build the most advanced car on the planet, but if the car doesn’t inspire confidence in the drivers, then it’s not going to win a championship.
Of course drivers will provide feedback, it is expected of them and it helps the engineers understand where the weaknesses or deficiencies may be, but ultimately the engineers will produce the fastest car they can with the compromises inherited to it… The MCL34 and MCL35 has similar characteristics and that’s because it was the best car the team could produce at that time, the MCL35M maintained those… I’m hoping that the MCL36 will be a car that suits Daniel a bit more, but it isn’t a car designed for or by Daniel, it is the fastest car the team has envisioned based on the current regulations and will have it’s own driving characteristics, regardless of what the drivers may like.
Regarding the suspension, what I’m trying to say is that the new suspension design has been in the works since 2020, before Daniel joined the team, so trying to say now that he influenced the design is simply wrong.
