Ferrari SF23
Re: Ferrari SF23
I've asked this question once or twice, but how does the back pressure of the rake blockage not influence the measurement?
A lion must kill its prey.
Re: Ferrari SF23
It does. The results are compared to corrected simulation results. One way is to simulate the car with those rakes, but it might be a wasted simulation with ATR in place...
jambuka
jambuka
Re: Ferrari SF23
Apparently PU reliability is good and team will run it at full power.
deadhead
Re: Ferrari SF23
Fede90
Fede90
Re: Ferrari SF23
The article says that Ferrari hadn’t used the engine at 100% on purpose, in order to hide to others teams.
Ferrari’s engine engineers have improved the efficency that should prevent extra heat in pre combustion chamber.
Schippke
Schippke
Re: Ferrari SF23
[quote=Fede90 post_id=1117331 time=1677672566 user_id=18219]
[/quote]
... much luck in the same way that Honda, Mercedes and Alpine probably didn't go 100% on purpose either; Again, this discussion is more about the team itself, rather than the visual aspects of SF23.
Back on topic, please!
Henk_v
Henk_v
86
Re: Ferrari SF23
Vanja #66 wrote:
28 Feb 2023, 21:00
..., front wing lacks a bit of downforce..
Ferrari has the smallest planform front wing of all '23 cars
(darn, I cant find that 10 cars viewed form above spic)
Re: Ferrari SF23
Henk_v wrote:
01 Mar 2023, 14:52
Indeed, I missed that :oops:
viewtopic.php?p=1114644#p1114644
To be honest, that gives a new perspective on a lot of things...
tpe
tpe
-4
Re: Ferrari SF23
Vanja #66 wrote:
01 Mar 2023, 15:07
Henk_v wrote:
01 Mar 2023, 14:52
LM10
LM10
121
Re: Ferrari SF23
Vanja #66 wrote:
01 Mar 2023, 15:07
Henk_v wrote:
01 Mar 2023, 14:52
So they used low downforce not only at the rear, but also at the front?
Re: Ferrari SF23
LM10 wrote:
01 Mar 2023, 15:49
Vanja #66 wrote:
01 Mar 2023, 15:07
Henk_v wrote:
01 Mar 2023, 14:52
Downforce is a combination of planform area and angle of attack.
f1316
f1316
82
Re: Ferrari SF23
LM10 wrote:
01 Mar 2023, 15:49
Vanja #66 wrote:
01 Mar 2023, 15:07
Henk_v wrote:
01 Mar 2023, 14:52
I mean, I had always assumed that they had trimmed off the FW to balance with the rear. I suppose though the difference would be in whether it’s just less cranked than it would be if they had a larger rear wing or a front wing designed to carry lower loads (more similar to 2019).
Re: Ferrari SF23
LM10 wrote:
01 Mar 2023, 15:49
Impossible to say, I was just surprised at the smaller planform that's definitely reducing the downforce. Whether the result is medium or low downforce front wing is hard to say, since the geometry is much more complex than rear wing.
What is clear is they are pushing hard for big outwash generation even if the downforce is not maximised. Big centerline load also means two more things - there will always be notable outwash (predictability for downstream aero regardless of planform) and drag reduction due to speed-flex is maximised.
It is actually an overal positive thing for me, I was convinced they were far more limited with downforce gains available at the front than at the back. As it stands, I'd say they have plenty of room to add downforce if needed. Of course, both wings provide less efficient downforce, so any addition will be minimal and carefully evaluated.
Re: Ferrari SF23
Engine topics should be continued in engine thread --> viewtopic.php?t=21958 :)
saviour stivala
saviour stivala
52
Re: Ferrari SF23
''FERRARI has increased the power on the straights, they take a lot from us, but we make up for that with our overall package'' Marko told Oe24. This is a 180 degree change of the situation last year. Last year the RB was faster on the straights especially with DRS but slower in the corners, This year FERRARI is faster on the straights but slower in the corners.
