Why?slimjim8201 wrote: - Rear tire drag reduced
I believe sidepods have overall same width and tyre is too far behind to get any shielding effect.
The 25 was not ugly neither is 26.Also it wasnt slow, not the fastest yes, but not slow...Slow is the HRT.Of course thats my opinion just as yours but its just that.An opinion...Everybody has onedjos wrote:The top Macca was ugly and slow, so I wonder if all ugly Macca's are slow (including the 26)?wickerbill wrote:
I wonder what justifies an F1 car beautiful? I think if thats not beautiful its at least sweet looking piece of machinery.Hope its fast as well,looking forward to more "secrets" coming to light.mtec80 wrote:Sorry McLaren guys (and this is my personal feeling) but this is the ugliest formula one car I've ever seen. I was really excited to see the new car but this was a bad surprise. I don't think that putting so much weight to the outer left and right can work.
Might this be exactly what they want, to create a channel that will keep air over the diffuser? I'm thinking of the Toyota GT-One here.kilcoo316 wrote: The damping effect of the upper surface of the sidepod reduces turbulence to small scale stuff anyway; this "tunnel" will do something similar. Sure, there may be some BL growth, but drop the sidepod upper surface far enough so that is channeled underneath and clear of the beam wing.
But I'm now also concerned about the vortex spilling off the upper nose surface during fast cornering - thats potentially going to run the length of the car now and screw up the beam wing (as well as being a low pressure zone in a very bad place).
Again, that is something not easily analysed in a windtunnel or by CFD, as its a highly dynamic event.
OK I see them now. From the top shot I was looking at, they seemed to be missing.timbo wrote:Pup wrote:I don't see it. Is it not integrated into the top wishbone?timbo wrote:This is not a switch "back" they have steering arm really low, closer to the lower wishbone.
I think it is a tad lower, but not considerably.impaero wrote:Does this car have a considerably lower frontal area than the others we've seen so far?
djos wrote: The top Macca was ugly and slow, so I wonder if all ugly Macca's are slow (including the 26)?
Makes sense, as they are clearly aiming for a clean flow path to the beam wing with the sidepod treatment, logically they would make sure the suspension bits up front will accommodate that as well, probably also the reason why the nose ends up being relatively low vs the others we've seen...feynman wrote: Anyhow this year, from the few shots I've seen thus far, I'm sticking with the earlier assertion that the suspension is raked at a much lower, less aggressive angle, and this has allowed he steering arm to be reintegrated into the wishbone assembly (The high angles were the only reason it popped-out two years ago).
Too late for you to agree with me ... cos I've just changed my mind.RacingManiac wrote:Makes sense ...
