xpensive
xpensive
214
Re: Formula One 1.6l turbo engine formula as of 2013
There you go, but I'd like to see the TC on lower left if you please.
And the admission pipe more horizontal ? :mrgreen:
xpensive
xpensive
214
Naah, I wanna see the block at 45, xhaust piping coming out at the same angle, but making a turn going vertical to the TC at
the bottom left, charge going front to the massive intercooler, while leaving the right side free for oil- and water radiators.
autogyro
autogyro
Nah, put the intercooler behind the roll hoop and the turbocharger over the bell housing.
No need for air intake behind drivers head or shark fin.
Upright engine for better tunnels.
Shaddock
Blackout wrote:Something like this ?
:mrgreen:
Peronally, I'd leave the turbo top mounted rather than underslung. The I/C can go into one of the sidepods but keep they will need to keep the pipework as short as possible to reduce lag.
A simple schematic of the plumbing on my car, which shouldn’t differ to much in principle to an F1 turbo engine.
IRL it looks like this;
I'd expect the F1 engines to have equal length manifolds, and possibly twin scroll.
It will be intresting how the teams split the exhaust to feed the diffusers on both sides of the car, now they have only one bank of cylinders.
xpensive
xpensive
214
Recall the stillborn Alfa Romeo turbo I4, ran only briefly in a Ligier, which was reported to have a spaghetti exhaust,
with pipng from each valve outlet. Pics anyone?
gridwalker
gridwalker
Would this be what you are looking for?
EDIT : Another view
donskar
donskar
Happy Holidays to all!
WhiteBlue
92
The one thing we have not seen is a 2010 F2 engine as fitted in the car and not on a test bench. That would be interesting.
Naw! I rather have something elegant and compact like this
AlsoImage
This is a street car with a 2.0l inline 4, notice that boost doesn't come on until 5,000rpm, it'll be the same, possibly worse, with a smaller engine
autogyro
autogyro
Hardly a 'street' car and not much use for the street with boost at that high rpm.
I would have used two smaller turbos, or a supercharger like my SLK (2 liter).
It does compare loosely with the new l4 F1 though.
Hanging the turbo down low will block areas needed for the DF tunnels and increase drag.
xpensive
xpensive
214
- Grid; There you go. Kinda dissapointed though, as I xpected to see eight separate pipes.
- Don; I guess a merry Christmas wouldn't be politically correct enough, but happy hanukka then!
- At WB; This here site would not be the same without you.
At Tomba and everyone else with nothing better to do, a merry x-mas.
timbo
timbo
113
Why are you online x?
Vikings are not into Christmas? :)
xpensive
xpensive
214
Being descendents of true vikings, we do not recognize neither Christ nor Mohammad, we obviously worship Tor and Oden.
232
Well it's a christian holiday,and the vikings flip flopped to the Christ god and you can't escape the festivities, merry Christmas!
About the Ferrari 4 cylinder concept engine. Were there any implications of having the intakes pointing to the ground?
It's a good idea in that the Turbo is within the foot print of the engine, though i prefer the behind the engine mounting.
Behind the engine has it's implications as well. Some mention the longer pipes being bad for heat transfer, though i've seen pretty long pipes used for side mounted turbos.
One pro is that the exhaust can be easier split to 2 sides when it's along the line of symmetry of the car.
