ryaan2904
ryaan2904
36
PlatinumZealot wrote:
21 Nov 2020, 17:11
ryaan2904 wrote:
21 Nov 2020, 09:06
On Chrono GP, they say that the 2021 rules for the floor and diffuser changes would not only affect the aerodynamics but also heat exchange for the engine. According to the them, the floor is so effective in blocking air entering from the sides that a high vacuum type suction created by the diffuser, which apart from aero gains also creates a large suction below the rear wing which helps in heat extraction. Enough heat extraction that all teams would need to innovate their cooling systems due to the 2021 rules.
Also, for the 2021 Ferrari engine, the cooling fluid for the engine will be maintained to whats now, 130° C, but the cooling fluid for the electrical components (battery i guess) will be upgraded to 70°C to give better electrical support. Doesn't mean that Ferrari is not upgrading the ICE part but they are definitely doing something new in their electrical systems.
Sounds very sensible.
Just from experience, typically for powerful industrial motors I would measure 80*C to 85*C armature temperature using IR camera so that 70*C figure sounds very realistic as a target. Basically they are increasing efficiency a bit more, in an easier way, by running the motors cooler.
But isn't it opposite to what mercedes did last year? Merc said that they did some progress with the cooling fluids and they were able to run them hotter. Can you explain this bit a little?
CFD Eyes of Sauron
Be careful not to confuse engine coolant temperature and electrical coolant temperatures.
For the heat engine the ideal world is to run it hotter, materials and lubricants permitting. The benefit is less energy loss and less cooling surface required. Ideally. So Mercedes has moved towards this, even designing the aero and suspension for hot tracks.
Again, and crucially the design and materials /fuels/ lubricants must permit this higher temperature running. I am not saying there is more waste heat either.
Electrical components are the opposite. You want to run them at cool temperature. Not cold, but cool. Hotter temperstures reduces current carrying capicty, magnetic fluxes reduce with higher temps. Insulation breaks down etc.
ryaan2904
ryaan2904
36
22 Nov 2020, 00:25
Cool stuff :D Thanks for the explanation!
CFD Eyes of Sauron
FDD
FDD
81
ryaan2904 wrote:
22 Nov 2020, 08:25
22 Nov 2020, 00:25
Here is extreme example for getting max performance from CPU cooling at -160 Celsius. Speed of CPU is overclocked from 3GHz to 8GHz. Start watch the video from 10 min. to see the process of cooling, nitrogen is used I think.
Just like extreme example for PlatinumZealot already wrote about "Electrical components are the opposite. You want to run them at cool temperature. Not cold, but cool. Hotter temperstures reduces current carrying capicty"
ryaan2904
ryaan2904
36
FDD wrote:
22 Nov 2020, 14:46
ryaan2904 wrote:
22 Nov 2020, 08:25
22 Nov 2020, 00:25
Cool stuff! That chip literally became a superconductor :lol:
Also, anyone noticed how that 'whirring' sound, like that of an electrical whine emitted by the 2018 and 2019 Ferrari engine stopped in 2020?
I really liked that sound. Hope it comes back again in 2021
CFD Eyes of Sauron
That could be down to mic placement.
The whirring sound is the cooling fan :lol:
ryaan2904
ryaan2904
36
godlameroso wrote:
23 Nov 2020, 16:43
It could be, but why keep the same mic placements in 2018 and 2019 but change it for 2020?
CFD Eyes of Sauron
nemanja
nemanja
FDD
FDD
81
nemanja wrote:
26 Nov 2020, 02:50
Actually nothing new in the video and also speculations only :D
ryaan2904
ryaan2904
36
https://www.mahle-powertrain.com/en/exp ... -ignition/
Soo, the Jet Ignition thing is real. The active version applied to a normal roadcar will increase the BTE to 45% (their aimed figures). It could be that Ferrari has touched down 50% BTE figures. Can't say for sure. Though Mercedes might have reached 60% by now :(
CFD Eyes of Sauron
subcritical71
90
ryaan2904 wrote:
27 Nov 2020, 06:14
Its been real for quite some time now :mrgreen: ... Mahle video from 2016 ->
I think you can just about see some individual battery cells there which I found interesting, if that's indeed the battery dangling down there.
Part of its housing is seen here, the purplish piece in the middle. Also, a view on the underside of the intercooler on the left.
ryaan2904
ryaan2904
36
So.. more pain for Ferrari fans oncoming next year :cry:
CFD Eyes of Sauron
mvfad
-1
I'm afraid about this supposed new engine. Ferrari has not managed to create a good engine during the last few years without using the gray area (aka cheat), will they be able to produce a good engine within the rules in less than 1 year, even more with all this covid issue?
