FW17 wrote: ↑21 Apr 2017, 16:02
PlatinumZealot wrote: ↑21 Apr 2017, 15:56
FW17 wrote: ↑21 Apr 2017, 10:54
Don't think compressor size is limited by putting it in a cradle between gearbox and engine
Ferrari have the shortest routing for air with the inter cooler sitting in the V of the engine. They have done something totally different with the intake plenum. Something clever in the way they have made it, if the accommodated the Variable lengths with it, it will be one incredible design.
PS: Somehow the Honda engine thread has become the all engine discussion thread
The variable length runner are upside-down (inverted) in my opinion. They point downward into the V of the engine. The plenum is a big box with the intercooler at the back and the runnuers draw air from he bottom.
PZ lets move this to Ferrari Engine thread before it gets deleted
onventional variable intake manifolds are quite weighty and space-engaging. They are also likely to have the intake manifolds twisted or narrowed such that high-end power output is affected. Ferrari F12tdf avoids these problems by adopting a different kind of variable intake manifold. Its V12 engine utilizes 2 sets of trumpets (the black ones in picture below) which can move within the intake plenums, varying the effective length of intake manifolds. The trumpets are moved by hydraulic actuators located between the two plenums. In the F12tdf, the trumpets vary between long and short positions, but theoretically this design can be easily modified to vary continuously between the two positions.
One shortcoming of this design is limited range of adjustment. As the movable trumpets are quite short, the difference beween long and short modes are not as big as conventional VIM systems. However, this problem could be solved by using multiple trumpet sections working in telescopic style.
