McLaren MCL33
FrukostScones
163
Re: McLaren MCL33
anyone actually noticed how they take the floor to fulfill the slanted rule?
Re: McLaren MCL33
What are the chances of Mclaren following Renault's exhaust layout and angle ?
Should work well with Mclaren's current upward bodywork at the rear ? ! ?
gambler
gambler
Re: McLaren MCL33
...I would bet it would let an upcoming car suck up even more.
Re: McLaren MCL33
mclaren111 wrote:
15 Mar 2018, 12:51
Not a lot I'd imagine, in terms of performance it's not worth much at all - maybe nothing if you're already turning your exhaust flow well enough to help link the diffuser flow with the wing - which is why most teams already have winglets and gurneys on the crash structure.
FW17
171
Re: McLaren MCL33
Is a periscope allowed?
Moose
Moose
52
Re: McLaren MCL33
FW17 wrote:
15 Mar 2018, 15:48
https://cdn-9.motorsport.com/images/mgl ... IMNYES.jpg
No - there can be only one exhaust (plus 2 wastegate exhausts). Exhausts have to exit within 100mm the car centre line, between 220mm and 235mm rear of the car centre line. The last 150mm must be a straight, circular cylinder. It may point 5° side to side, and 5° up, but no more.
FW17
171
Re: McLaren MCL33
Moose wrote:
15 Mar 2018, 16:33
FW17 wrote:
15 Mar 2018, 15:48
Totally aware of that
Asked if a periscope bodywork can be done over the exhaust pie on top of the crash structure
Jackles-UK
Re: McLaren MCL33
FW17 wrote:
15 Mar 2018, 16:37
Moose wrote:
15 Mar 2018, 16:33
FW17 wrote:
15 Mar 2018, 15:48
The photo you posted isn't actually showing a central periscope (it is two symmetrical exhaust exits either side of he engine cover) but I don't think there's anything in the rules that would restrict one per sé.
The issue with it though is that a lot of the hot areas of the car are right at the back of the car (such as the gearbox) so an exit halfway down the engine cover wouldn't be of much use as it would limit the amount of cool air delivered to these extremities.
Moose
Moose
52
Re: McLaren MCL33
FW17 wrote:
15 Mar 2018, 16:37
No - body work isn't allowed in that area - hence why monkey seats aren't allowed any more.
Re: McLaren MCL33
Performance Talk has been moved to the Team Forum, Renault Rear Light Talk to the Trash Bin. :D
Re: McLaren MCL33
MCL32 Abu Dhabi vs MCL33 test spec
Nicktendo86
Nicktendo86
Re: McLaren MCL33
Floor is different but the bargeboards look almost identical. Would imagine this would be one of the major areas for the Australia update.
Re: McLaren MCL33
rccrdc
rccrdc
Re: McLaren MCL33
Mat-tes
Mat-tes
30
Re: McLaren MCL33
I'd say the openings and inlets were already there during testing, shape wise it's probably a bit different but I'd assume they function the same.
The back part where it goes up was also there, it's for the rear wing support.
However, the black paint is new and it's around where the burned lines were during both weeks of testing.
Could they have surfaced the bodywork with the same material that the teams used to apply during the blown diffusor era? All teams had the surroundings of the exhausts painted in black, similar to here.
Those could be easy fixes for McLaren while they come up with a better internal design and cooling package for Barcelona, maybe.
