ringo wrote:I think the team could have replaced the tie rod. As long as a part being replaced is of the same weight, i think the mechanics are free to replace it.
We see this with the front wings. It would set him back in time to replace that tie rod, but a lap1 stop then onto hard tyres could have put him in the points.
On the surface that may appear valid, but it's based on the assumption that just the rod was damaged, and nothing else. And even if a suspension part could be changed so quickly, another assumption is made, that the suspension is aligned and the geometry is as before.
If the suspension geometry is not correct, or even worse, a part weakened by the previous impact failed, finding out at the end of a straight at Monza isn't a good place to be.
The assessment of risk versus reward doesn't make sense in this application when you consider how long it would take to get back to the pits, replace such a part, and have a realistic chance at capturing some points when you have the facts available that even 10th place is almost always around a minute of the winner.
Here are the finishing times for tenth place so far.
Bahrain 1:02.5
Australia 1:09.4
Malaysia 1:18.9
China 1:01.7
Spain +1 lap
Monaco 8.1
Turkey 1:05.6
Canada +1 lap
Valencia 44.4
Great Britain 42.0
Germany + 1 lap
Hungary + 1 lap
Belgium 34.8
So based on results this year, the car would have to be able to limp back to the pits, and change the suspension component within 2 laps, period. Since the leaders would be lapping at under 1:30, that gives you exactly 3 minutes from the first indication of trouble to effecting a repair and getting the car back on the track and competitive.
And of course, if you get it wrong and miss something in the process, there is the possibility of a very bad accident. Is it really worth the risk of adding Hamilton's name to the list of Ascari, Peterson, and Rindt?
