They know what they're doing in Milton Keynes!chapmanlung wrote:i really like how they place the sponsers just ahead of the suspension, becuase they know that, thats where people will be taking the pictures
Forgive me if I've missed something, but I don't recall the floor having a piece cut out of it that the exhaust blows into before. When did this happen? It's clearly very rough because you can see the ad-hoc cut. They're making a bit of a mockery of the regulations, aren't they? There's quite a bit of mileage left in that line of development. I didn't think that was legal to be honest.muelte wrote:Exhaust blown diffuser detail:
They had it really long ago... I think it was in Valencia. It's legal because of the outer 50mm (or something) regulation, so they can have whatever they want there.segedunum wrote: Forgive me if I've missed something, but I don't recall the floor having a piece cut out of it that the exhaust blows into before. When did this happen? It's clearly very rough because you can see the ad-hoc cut. They're making a bit of a mockery of the regulations, aren't they? There's quite a bit of mileage left in that line of development. I didn't think that was legal to be honest.
Yes, what you can see there is the pull-rod. Look at where the exhaust is and the airflow around it and you'll realise why a push-rod just won't cut it where you have to do the work around the diffuser this year.
It has been there a long time but it's got nothing to do with the 50mm thing. The floor is cut out so there is no problem. The view above shows that they have cut out more of the floor plate than originally done, however. In effect, the outer part of the diffuser is now just a very short bit of floor with a big (relative to the length of the floor section) diffuser behind it. It's a small version of the Renault method of blowing in to the front of the floor.Muulka wrote:They had it really long ago... I think it was in Valencia. It's legal because of the outer 50mm (or something) regulation, so they can have whatever they want there.segedunum wrote: Forgive me if I've missed something, but I don't recall the floor having a piece cut out of it that the exhaust blows into before. When did this happen? It's clearly very rough because you can see the ad-hoc cut. They're making a bit of a mockery of the regulations, aren't they? There's quite a bit of mileage left in that line of development. I didn't think that was legal to be honest.
I stand corrected, but I mentioned the 50mm rule as that defines the maximum size that those cut-outs can be (al least width-wise). Unless I'm wrong againJust_a_fan wrote:It has been there a long time but it's got nothing to do with the 50mm thing. The floor is cut out so there is no problem. The view above shows that they have cut out more of the floor plate than originally done, however. In effect, the outer part of the diffuser is now just a very short bit of floor with a big (relative to the length of the floor section) diffuser behind it. It's a small version of the Renault method of blowing in to the front of the floor.Muulka wrote:They had it really long ago... I think it was in Valencia. It's legal because of the outer 50mm (or something) regulation, so they can have whatever they want there.segedunum wrote: Forgive me if I've missed something, but I don't recall the floor having a piece cut out of it that the exhaust blows into before. When did this happen? It's clearly very rough because you can see the ad-hoc cut. They're making a bit of a mockery of the regulations, aren't they? There's quite a bit of mileage left in that line of development. I didn't think that was legal to be honest.
It's the one thing that the others should be looking at copying in my view. Ferrari have already done so and I think McLaren should do too if they can. It's a great example of a simple system and makes McLaren's blowing system look what it is - over-complicated.
Really? Guess I misunderstood what was written earlier....n smikle wrote:Nope you cut the floor however you want. As long as that cut makes a continuous section if it lies on the step plane. I think RB7 exhausts are actually above the step plane but slight aimed downwards as you can see. The area right at the exhaust tip will be filled in to meet regulations I figure.
Wow. Now I understand why you seemed so confused earlier in this discussion. I mentioned how rough the RB exhaust system looked and you just instantly defended it, obviously not looking at the evidence.segedunum wrote: Forgive me if I've missed something, but I don't recall the floor having a piece cut out of it that the exhaust blows into before. When did this happen? It's clearly very rough because you can see the ad-hoc cut. They're making a bit of a mockery of the regulations, aren't they? There's quite a bit of mileage left in that line of development. I didn't think that was legal to be honest.
Ok. I don't actually remember the McLaren floor except from fome F1.com articles, because I only got into F1 last year lol. And I can't imagine looking through the whole F1 technical regs.Just_a_fan wrote:remember the McLaren cut out floor of two years ago? This is just the same sort of thing. There is no requirement to have the floor plate there at all except where there is bodywork above. The reason is to prevent profiled undersides e.g. "ground effect cars".
