321apex wrote:I must respectfully say that "you ain't right" on this onechip engineer wrote:The air is not going in because there is not enough pressure differential to give enough airflow in a NA engine at that rpm.321apex wrote:...
Here you have a typical power curve, where following a power peak, it tails off. Why is that? Well simply put, with the incremental RPM there isn't equal incremental air going into the combustion chambers to make the power go up.
https://lh6.googleusercontent.com/-mKvX ... +curve.png
Why is it not going in? Well something is preventing it I guess and choked flow is one of the key factors.
.... When the flow is "choked" you can not bring any additional flow thru pressure differential increase. It is STUCK! at the level it is.
What would "uncork it"? Cam change, YES YES YES. Now you may ponder the question what does cam change do?
Rest assured, that I am not a pioneer in using analogies drawn from one area of science to explain others. In this case, the NA analogy with Turbo is quite nearly identical if you understand the subject. If my argument makes little sense to you, then you should review in detail the information I provided along until you understand it. What I share here with you is something that was never given to me on a platter. You are getting the gist and are not liking it.chip engineer wrote:Using airflow limits in NA engine to make a point about a boosted engine makes no sense.
Since when??? Are you inventing new principles of Otto cycle engine operation? Maybe you can provide some citations from technical literature to support this.chip engineer wrote:Also, with the fuel flow limit, there is no air flow increase needed at high rpm.
Although some measure of charge stratification is possible with direct fuel injection, however what you are expecting isn't supported by any thermodynamic principles.
Now that you seem to accept what everyone has been telling you: that with a fuel flow limit, there is no air flow increase needed at high rpm, should we expect an apology for some of your insulting remarks about our knowledge?
