Ferrari F138
timbo
timbo
111
Re: Ferrari F138
Apparently the hole was planned long in advance.
Abarth
45
Re: Ferrari F138
Could the hole be a cooling air inlet which will be used only in hotter races, and if not needed they can cover it elegantly?
Or, alternatively, an air channel to feed the central part of diffusor, similar to what RB does, but sucking the air from the front and not from the rear part of the sidepods?
Consider&Go
Consider&Go
Re: Ferrari F138
timbo wrote:Apparently the hole was planned long in advance.
Do you have a source please?
"I have no idols. I admire work, dedication and competence." - Ayrton Senna
radosav
radosav
Re: Ferrari F138
What if this hole is used for taking humidity from air! Is it possible to use water as balast in car ? So after the race start you evaporate water from balast tanks and during last 15 laps you collect it back from air? It could work in Malaysia! Please don't give me negative votes !
Re: Ferrari F138
He does not have to. You can clearly see it's built into the chassis. It's takes alot of time to develop a chassis that a strong enough to survive the crash test, yet still have that big hole there.
I was also wondering, with the front bulkhead having tightly regulated and standarised dimensions, how thin the actual nose would have to be? They need to leave enough room beneath the nose for air to reach the hole, yet can't go higher then 550mm.
aral
aral
26
Re: Ferrari F138
radosav wrote:What if this hole is used for taking humidity from air! Is it possible to use water as balast in car ? So after the race start you evaporate water from balast tanks and during last 15 laps you collect it back from air? It could work in Malaysia! Please don't give me negative votes !
OK, I wont give you a negative vote, but that certainly deserves one! :lol: :lol: :lol:
scuderiaF2012
scuderiaF2012
-1
Re: Ferrari F138
i think that is the dumbest explination i have ever heard... :lol:
Re: Ferrari F138
He is atleast trying; I find it more useful then the 2 posts above me.
Mr.G
34
Re: Ferrari F138
radosav wrote:What if this hole is used for taking humidity from air! ...
I think it will be used for airodynamical purpouses. Going under the driver to the rear of the car.
Crabbia
Crabbia
Re: Ferrari F138
this might be even more ridiculous and get me down voted but what it it flows the other way. what if the hole we see works as a venturi with air flowing past it and pulling air out of the duct? and air is sucked from the cockpit underneath the car?
only reason i think this is having the air flowing through the duct and out the cockpit opening is useless.
having the air flowing to the rear of the car requires ducts in an area of the car where space is a premium.
A wise man once told me you cant polish a turd...
Re: Ferrari F138
Do not forget mercedes succeeded in laying down pipes from the rear to the front, and if atleast one part of the car last year was positive, then it was their sidepods. They packaged their car very well with the pipes; ferrari should be able to do the same.
Perhaps we have yet to see to where it leads? Ferrari. Might have opted to use the first testing week to examine the effects of having a hole there and will only put the exit of it at a later stage.
scuderiaF2012
scuderiaF2012
-1
Re: Ferrari F138
i think it would work if the car would be driven in REVERSE....lol...all jokes aside the intake we saw at the last day of test 1 is for air intake ONLY...weather it's for driver cooling or meant for aero purposes, no one knows yet...only Ferrari know... i'm sure we're gonna hear the more experienced critics (like james allen, or garry A.) talk more about it...
Re: Ferrari F138
Scarbs last year was the first to uncover the ddrs mystery. I think we should follow his tweets closely about this one.
Coefficient
Coefficient
Re: Ferrari F138
I think this is why they have that ugly catfish mouth scoop fitted when they're experimenting with the duct.
Owen.C93
Owen.C93
177
Re: Ferrari F138
turbof1 wrote:Scarbs last year was the first to uncover the ddrs mystery. I think we should follow his tweets closely about this one.
What did he tweet?
