stefan_ wrote:Right side of the exhaust area.
http://www.formule1.nl/media/uploads/me ... 7950.4.jpg
Btw, that's a new floor with a new non-curved vane for the rear tire instead of the r shaped one they had ealier
No it's not. Look more closely. There are other images that show definite ramp-shapeditems on the top of the drive shaft shroud. They are positioned about mid-length of the shroud and are approx 50mm in length (measured along the axle line). Lots of silver tape on the shroud to the rear 0f the ramp features.Coefficient wrote:That's the bottom of the engine cover you're seeing there. It extends right to the rear of the car like a tunnel.Just_a_fan wrote:I wonder what the silver reverse ramps on top of the driveshaft cowling are for. Maybe sensors looking at the exhaust (in the same way they look at the tyres with IR sensors) or maybe scooping some air in to the cowling to keep something cool. Perhaps it's part of the signalling system for the passive DRD thingy.stefan_ wrote:
You are right, I see em!Just_a_fan wrote:You can see them very clearly here:
Isnt that the dip in the floor we have seen on the top side but now from the back of the diffuser ? Don't think its holes but at least its not a flair floor which must mean they got a loophole.beelsebob wrote:What I'm more interested in that a bunch of tape and sensor on the drive shaft shroud is these:
I see two possibilities:
1) Merc have once again found a loop hole that allows them to open up a hole into the diffuser, and this is what the unexplained trough on the rear of the floor is.
2) Even if they haven't done that, that's a pretty radical new diffuser design.
Follow the carbon fiber at the bottom of the sidepodSchulteiss wrote:^^ dips down where exactly? I cannot see it dipping down?
Either my eyes are tricking me, or the edge you are speaking about is above the floor?Huntresa wrote:Follow the carbon fiber at the bottom of the sidepodSchulteiss wrote:^^ dips down where exactly? I cannot see it dipping down?
Save it and zoom if you wanna see better but if you see the sun beam that looks like a knife, just before that you see the carbon fibre edge going down. You can also see and edge in the floor at this point.
The carbon fiber dips down and under the bulky area at the back. That's what I'm seeing, cause you clearly see the carbon fiber is rounded where it dips down but its hard for me in paint to paint that area to show properly. And I see that its rounded there and goes down cause its straight up until this pointSchulteiss wrote:Either my eyes are tricking me, or the edge you are speaking about is above the floor?Huntresa wrote:Follow the carbon fiber at the bottom of the sidepodSchulteiss wrote:^^ dips down where exactly? I cannot see it dipping down?
