Are you kidding, so why was he doing that all the time? This is really incredible - just one-liner against all evidence. How the hell did he not gain an advantage? He gained every time he did it, he only overtook Alonso because he did it three times in one lap. Did you see corrections, lines and hesitation in Copse when Vettel tried to stay on the track? Why do you think every other driver (Hulkenberg etc.) got warning after doing the same once or twice?WilliamsF1 wrote: After all the running wide, he did not gain an advantage (still behind) so why penalize? The place he tried his overtakes were on wellington straight, luffield and into copse.
This is really one of those indisputable situation. Did you miss clear direction about qualifying - 100% clear indication that you DO GAIN LAP TIME MEASURED IN SECONDS NOT OPINIONS by going wide in corners in question? Did you miss directive that every driver that goes wide in those corners gains an advantage and will de reported to stewards? Meanwhile FIA put their proverbial head in its proverbial bottom and pretended nothing happened.
