Still this discussion. It’s a normal move, closing the line at corner exit. Most smart drivers yield, some don’t and complain (or know, like Bottas that there is an excellent run off area at turn one)zeph wrote: ↑23 Oct 2017, 18:48I know. I was okay with Verstappen's move on Raikkonen, but the way he ran Bottas off the track was not classy.
That's what we had before 1994. Drivers had to be skilled. If you left the track, you would lose time, and you might get hurt. It's different now. We don't want drivers to get hurt. But we still want drivers to be skilled. Well, I do anyway. That's why I'm in favor of always penalizing drivers when they leave the track. And also because I don't buy the argument that you only get an advantage when you gain time in that particular corner. Leaving the track means you get some kind of advantage, always, and should therefore be penalized, always.
Charlie Whiting and his team let people run wide all over the track all weekend long and then in the end when its an overtake then suddenly they feel the need to act.notsofast wrote: ↑23 Oct 2017, 19:22That's what we had before 1994. Drivers had to be skilled. If you left the track, you would lose time, and you might get hurt. It's different now. We don't want drivers to get hurt. But we still want drivers to be skilled. Well, I do anyway. That's why I'm in favor of always penalizing drivers when they leave the track. And also because I don't buy the argument that you only get an advantage when you gain time in that particular corner. Leaving the track means you get some kind of advantage, always, and should therefore be penalized, always.
Yes, we want drivers to try, not to crash.notsofast wrote: ↑23 Oct 2017, 19:22That's what we had before 1994. Drivers had to be skilled. If you left the track, you would lose time, and you might get hurt. It's different now. We don't want drivers to get hurt. But we still want drivers to be skilled. Well, I do anyway. That's why I'm in favor of always penalizing drivers when they leave the track. And also because I don't buy the argument that you only get an advantage when you gain time in that particular corner. Leaving the track means you get some kind of advantage, always, and should therefore be penalized, always.
That's such a brilliant suggestion.Jolle wrote: ↑23 Oct 2017, 19:41With the current state of tech its so simple: small transponders on the corners that you may not cut/run wide, a sensor in the bottom of the car. Going over that transponder line, your power is cut by, for instance 30% for 5 seconds. You won't crash, you won't damage your car, the stewards don't have to get involved and you as the driver take the risk yourself.
They've used this system in few cases already. I remember last year @ Hungary. Dunno why they dropped itGrandAxe wrote: ↑23 Oct 2017, 19:50That's such a brilliant suggestion.Jolle wrote: ↑23 Oct 2017, 19:41With the current state of tech its so simple: small transponders on the corners that you may not cut/run wide, a sensor in the bottom of the car. Going over that transponder line, your power is cut by, for instance 30% for 5 seconds. You won't crash, you won't damage your car, the stewards don't have to get involved and you as the driver take the risk yourself.
The system wasn’t automated so it was still up to the stewards.F1NAC wrote: ↑23 Oct 2017, 20:05They've used this system in few cases already. I remember last year @ Hungary. Dunno why they dropped itGrandAxe wrote: ↑23 Oct 2017, 19:50That's such a brilliant suggestion.Jolle wrote: ↑23 Oct 2017, 19:41With the current state of tech its so simple: small transponders on the corners that you may not cut/run wide, a sensor in the bottom of the car. Going over that transponder line, your power is cut by, for instance 30% for 5 seconds. You won't crash, you won't damage your car, the stewards don't have to get involved and you as the driver take the risk yourself.
https://www.formula1.com/en/latest/head ... ngary.html
Put big fat kerbs (trampolines by kvyat) that will punish you by damaging your suspension if they arent capable to put gravel
i vote in favour of that systemJolle wrote: ↑23 Oct 2017, 19:41Yes, we want drivers to try, not to crash.notsofast wrote: ↑23 Oct 2017, 19:22That's what we had before 1994. Drivers had to be skilled. If you left the track, you would lose time, and you might get hurt. It's different now. We don't want drivers to get hurt. But we still want drivers to be skilled. Well, I do anyway. That's why I'm in favor of always penalizing drivers when they leave the track. And also because I don't buy the argument that you only get an advantage when you gain time in that particular corner. Leaving the track means you get some kind of advantage, always, and should therefore be penalized, always.
Yellow rumble "breads" kill the suspension, the tub or their backs. Grass on the inside will make cars spin into the racing line and gravel traps prevent drivers to take a bit of a risk (and every race will be a progression like Monaco).
The other matter is that on most circuits are used for more then F1 and you don't want your customers/owners/sponsors write off their Ferrari's.
Mark Webber got done for exactly the same move at Singapore (on Hamilton iirc) a few years ago, so it's not like there isn't a precedent for it.NathanOlder wrote: ↑22 Oct 2017, 23:15He cut the corner. Its "Well done stewards"Restomaniac wrote: ↑22 Oct 2017, 23:12Well then it wasn't him leaving the track to overtake as the room was there. So he has just been penalised for leaving the track. Nice 1 stewards.NathanOlder wrote: ↑22 Oct 2017, 23:07http://picpaste.com/20171022_220532-2e6NH5J7.jpg
Phil, Max didnt need to be here. He had room to keep wheels on the track
What if the transponder fails? That driver then gets an advantage over everyone else. Cars are different shapes, where would the transponder be? Short cars might get an advantage etc. Terrible idea. There was nothing wrong with the decision other than it's unpopular.maxxer wrote: ↑24 Oct 2017, 01:03i vote in favour of that systemJolle wrote: ↑23 Oct 2017, 19:41With the current state of tech its so simple: small transponders on the corners that you may not cut/run wide, a sensor in the bottom of the car. Going over that transponder line, your power is cut by, for instance 30% for 5 seconds. You won't crash, you won't damage your car, the stewards don't have to get involved and you as the driver take the risk yourself.
If the transponder fails the car should retire, much like with a DRS failure. The technology can be something as simple, cheap and robust as RFID.Diesel wrote: ↑24 Oct 2017, 13:23What if the transponder fails? That driver then gets an advantage over everyone else. Cars are different shapes, where would the transponder be? Short cars might get an advantage etc. Terrible idea. There was nothing wrong with the decision other than it's unpopular.maxxer wrote: ↑24 Oct 2017, 01:03i vote in favour of that systemJolle wrote: ↑23 Oct 2017, 19:41With the current state of tech its so simple: small transponders on the corners that you may not cut/run wide, a sensor in the bottom of the car. Going over that transponder line, your power is cut by, for instance 30% for 5 seconds. You won't crash, you won't damage your car, the stewards don't have to get involved and you as the driver take the risk yourself.
