Old Hockenhaim .... -1SmallSoldier wrote: ↑22 Mar 2019, 20:42This is a chart with the levels of downforce required per GP/Track... I guess that if the team has aimed for a low downforce setup or a car that is more suited for circuits with a low downforce requirements, it could be a in a good position more often than not... Bahrain should be a good test for this theory.
https://uploads.tapatalk-cdn.com/201903 ... 2a17d1.jpg
It's possible they run low down force because they cant get enough df on the front wing and therefore cant increase the rear wing too much.SmallSoldier wrote: ↑22 Mar 2019, 20:42This is a chart with the levels of downforce required per GP/Track... I guess that if the team has aimed for a low downforce setup or a car that is more suited for circuits with a low downforce requirements, it could be a in a good position more often than not... Bahrain should be a good test for this theory.
Can you elaborate your point a bit?mwillems wrote: ↑23 Mar 2019, 05:21It's possible they run low down force because they cant get enough df on the front wing and therefore cant increase the rear wing too much.SmallSoldier wrote: ↑22 Mar 2019, 20:42This is a chart with the levels of downforce required per GP/Track... I guess that if the team has aimed for a low downforce setup or a car that is more suited for circuits with a low downforce requirements, it could be a in a good position more often than not... Bahrain should be a good test for this theory.
I believe he is trying to say that Mclaren have more downforce generating potential at the rear of the car but they are not exploiting this potential because they cannot balance the downforce at the front end. If they do in fact produce their maximum downforce at the rear of the car, the car would then be unbalanced as they cannot produce the necessary downforce at the front of the car. This would, of course, lead to a car with a lot of understeer. I think this is what mwilliams is saying. It is always easier to produce the necessary downforce with the front wing however so I personally don't believe this reasoning.M840TR wrote: ↑23 Mar 2019, 13:52Can you elaborate your point a bit?mwillems wrote: ↑23 Mar 2019, 05:21It's possible they run low down force because they cant get enough df on the front wing and therefore cant increase the rear wing too much.SmallSoldier wrote: ↑22 Mar 2019, 20:42This is a chart with the levels of downforce required per GP/Track... I guess that if the team has aimed for a low downforce setup or a car that is more suited for circuits with a low downforce requirements, it could be a in a good position more often than not... Bahrain should be a good test for this theory.
You're allowed to replace wiring. You can also replace seals in some places. Don't forget the PUs have layers of shielding and the paint cracks with heat easily but. Agreed it doesn't look good.M840TR wrote: ↑21 Mar 2019, 14:00Well the monocoque probably didn't suffer anything since it's further ahead. The brake ducts, floor and diffuser might have. As for the engine, the mgu-K, manifold and wiring is definitely gone. There's a good chance the block might've been damaged as well._cerber1 wrote: ↑21 Mar 2019, 09:48Horror, it looks like the chassis and engine suffered very badly.
https://radikal.ru
I have 2 guesses (so they could be way off the mark)... But, when designing a new car, you should can either shoot for a design that maximizes performance in some type of races or that has average performance in a wide array of races.jh199 wrote:I believe he is trying to say that Mclaren have more downforce generating potential at the rear of the car but they are not exploiting this potential because they cannot balance the downforce at the front end. If they do in fact produce their maximum downforce at the rear of the car, the car would then be unbalanced as they cannot produce the necessary downforce at the front of the car. This would, of course, lead to a car with a lot of understeer. I think this is what mwilliams is saying. It is always easier to produce the necessary downforce with the front wing however so I personally don't believe this reasoning.
Yup. Their front wing design isn't that extreme anyway and they seemed to have resolved their understeer issues for quali in Melbourne. It's much more likely - as @smallsoldier pointed out - they're aiming for a car that works in most circuits; then slowly developing it into something with a wider working window throughout the season.jh199 wrote: ↑23 Mar 2019, 17:06I believe he is trying to say that Mclaren have more downforce generating potential at the rear of the car but they are not exploiting this potential because they cannot balance the downforce at the front end. If they do in fact produce their maximum downforce at the rear of the car, the car would then be unbalanced as they cannot produce the necessary downforce at the front of the car. This would, of course, lead to a car with a lot of understeer. I think this is what mwilliams is saying. It is always easier to produce the necessary downforce with the front wing however so I personally don't believe this reasoning.
Layers of shielding? This is the first I'm hearing about this...diffuser wrote: ↑23 Mar 2019, 18:31You're allowed to replace wiring. You can also replace seals in some places. Don't forget the PUs have layers of shielding and the paint cracks with heat easily but. Agreed it doesn't look good.M840TR wrote: ↑21 Mar 2019, 14:00Well the monocoque probably didn't suffer anything since it's further ahead. The brake ducts, floor and diffuser might have. As for the engine, the mgu-K, manifold and wiring is definitely gone. There's a good chance the block might've been damaged as well._cerber1 wrote: ↑21 Mar 2019, 09:48Horror, it looks like the chassis and engine suffered very badly.
https://radikal.ru
It is usually to not allow the heat out. the gold sheeting.M840TR wrote: ↑23 Mar 2019, 20:34Layers of shielding? This is the first I'm hearing about this...
I saw that, I thought it was BS. It's based on the race lap averages. By the end of the race most of the drivers were struggling to stay awake.M840TR wrote: ↑22 Mar 2019, 19:50Interesting. Most of the time is lost in the corners and made up on the straights. I'm not sure this much focus on low-drag is beneficial for factors such as tyre deg etc.
https://i.redd.it/xpzecu8ckon21.png
Yes it was a late night post. I am referring to the car being understeery. I'm not convinced it is gone yet but stand to be completely wrong. I don't think they would run the car to lose so much time in corners to gain a little speed on the straights because they wanted to, or it was the natural choice. I wonder if the balance issue was resolved by simply carrying less aero on the rear.M840TR wrote: ↑23 Mar 2019, 20:30Yup. Their front wing design isn't that extreme anyway and they seemed to have resolved their understeer issues for quali in Melbourne. It's much more likely - as @smallsoldier pointed out - they're aiming for a car that works in most circuits; then slowly developing it into something with a wider working window throughout the season.jh199 wrote: ↑23 Mar 2019, 17:06I believe he is trying to say that Mclaren have more downforce generating potential at the rear of the car but they are not exploiting this potential because they cannot balance the downforce at the front end. If they do in fact produce their maximum downforce at the rear of the car, the car would then be unbalanced as they cannot produce the necessary downforce at the front of the car. This would, of course, lead to a car with a lot of understeer. I think this is what mwilliams is saying. It is always easier to produce the necessary downforce with the front wing however so I personally don't believe this reasoning.
But that's aft the monocoque to protect the fuel tank etc. Engine is pretty much exposed. It's cooled by the intercooler air which we see exited at the back.
If it is based on race data and not quali then it's a bit unreliable. Too many variables.diffuser wrote: ↑23 Mar 2019, 22:22I saw that, I thought it was BS. It's based on the race lap averages. By the end of the race most of the drivers were struggling to stay awake.M840TR wrote: ↑22 Mar 2019, 19:50Interesting. Most of the time is lost in the corners and made up on the straights. I'm not sure this much focus on low-drag is beneficial for factors such as tyre deg etc.
Do you mean less wing angle?mwillems wrote: ↑23 Mar 2019, 23:12Yes it was a late night post. I am referring to the car being understeery. I'm not convinced it is gone yet but stand to be completely wrong. I don't think they would run the car to lose so much time in corners to gain a little speed on the straights because they wanted to, or it was the natural choice. I wonder if the balance issue was resolved by simply carrying less aero on the rear.M840TR wrote: ↑23 Mar 2019, 20:30Yup. Their front wing design isn't that extreme anyway and they seemed to have resolved their understeer issues for quali in Melbourne. It's much more likely - as @smallsoldier pointed out - they're aiming for a car that works in most circuits; then slowly developing it into something with a wider working window throughout the season.jh199 wrote: ↑23 Mar 2019, 17:06
