is it legal? I think it is not.yener wrote: ↑08 Sep 2020, 21:55The rear suspension is making the rear wing bend / change in angle someway. This way they have less drag on the straights, the problem is that ad mid an high speed corners, the suspension is still causing the rear wing into an angle and by that they lose df on the rear. Just watch the onboards
Sorry for my earlier post. The rear wing flexing has nothing to do with the suspension angle / geometry. But i'm almost a 100% sure the twitchy rear of the RB16 is due to the flexing rear wing. RB16 is simply not fast enough trough the mid and highspeed courners, because that the rear wing angle is not stable from a certain speed which cause instability at the rear. Just watch the movie below.etusch wrote: ↑09 Sep 2020, 14:19is it legal? I think it is not.yener wrote: ↑08 Sep 2020, 21:55The rear suspension is making the rear wing bend / change in angle someway. This way they have less drag on the straights, the problem is that ad mid an high speed corners, the suspension is still causing the rear wing into an angle and by that they lose df on the rear. Just watch the onboards
I think Redbull just changes ride hight of rear and this automatically change whole cars angle. I think this is core of high rake concept
Interesting theory, but I find it difficult to believe the handling issues are caused by Red Bull miscalculating the stiffness of the rear wing endplates, and the degree of rear wing deflection (literally the degree of deflectionyener wrote: ↑10 Sep 2020, 03:08Sorry for my earlier post. The rear wing flexing has nothing to do with the suspension angle / geometry. But i'm almost a 100% sure the twitchy rear of the RB16 is due to the flexing rear wing. RB16 is simply not fast enough trough the mid and highspeed courners, because that the rear wing angle is not stable from a certain speed which cause instability at the rear. Just watch the movie below.
What is the effect of that 'moving' airstream on cars behind? does it destabilise them as it is inconsistent?hecti wrote: ↑10 Sep 2020, 14:21The wing is doing exactly what it is meant to be doing, the flex is 100% designed into the pilars, resulting in less drag at higher speeds (and slightly less downforce as well). Whether that amount of flex is too much according to the rules is something else entirely, but it seems to be doing its job as intended (just like the front wing flex in the early 2010s)
Why would it destabilize the car behind more? If you are reducing drag and downforce with this flex motion, it would make for a slightly less turbulent wake. The flex looks pretty consistent, and if you look at other cars wings (both front and rear) you will notice flex as well, maybe not to the same degree, as Redbull seem to be the kings of well engineered wing flex.Big Tea wrote: ↑10 Sep 2020, 16:27What is the effect of that 'moving' airstream on cars behind? does it destabilise them as it is inconsistent?hecti wrote: ↑10 Sep 2020, 14:21The wing is doing exactly what it is meant to be doing, the flex is 100% designed into the pilars, resulting in less drag at higher speeds (and slightly less downforce as well). Whether that amount of flex is too much according to the rules is something else entirely, but it seems to be doing its job as intended (just like the front wing flex in the early 2010s)
I wondered the same when we see slo-mo shots of the front wing waving about in a corner.
I was thinking of a gust effecthecti wrote: ↑10 Sep 2020, 16:52Why would it destabilize the car behind more? If you are reducing drag and downforce with this flex motion, it would make for a slightly less turbulent wake. The flex looks pretty consistent, and if you look at other cars wings (both front and rear) you will notice flex as well, maybe not to the same degree, as Redbull seem to be the kings of well engineered wing flex.Big Tea wrote: ↑10 Sep 2020, 16:27What is the effect of that 'moving' airstream on cars behind? does it destabilise them as it is inconsistent?hecti wrote: ↑10 Sep 2020, 14:21The wing is doing exactly what it is meant to be doing, the flex is 100% designed into the pilars, resulting in less drag at higher speeds (and slightly less downforce as well). Whether that amount of flex is too much according to the rules is something else entirely, but it seems to be doing its job as intended (just like the front wing flex in the early 2010s)
Flex wings are nothing new, the extent on which you see here isn't either.yener wrote: ↑10 Sep 2020, 03:08Sorry for my earlier post. The rear wing flexing has nothing to do with the suspension angle / geometry. But i'm almost a 100% sure the twitchy rear of the RB16 is due to the flexing rear wing. RB16 is simply not fast enough trough the mid and highspeed courners, because that the rear wing angle is not stable from a certain speed which cause instability at the rear. Just watch the movie below.
